Error opening Notebook Server (.nbserver.crt)
1467
05-29-2019 09:13 AM
FabioD_Ovidio
Hello all,
I installed and federated Notebook server Standard with ArcGIS Base Deployment 10.7.
When I try to open a notebook I can see from docker that the container is created and than its status is "running" but I have an error related to the SSL certificate like this:
".nbserver.crt file doesn't exist"
so I created .crt file and added it into the following dir
<arcgisnotebookserver>\directories\arcgisworkspace\<my_user>
and I receive the following error
ssl.SSLError: [X509: KEY_VALUES_MISMATCH] key values mismatch
so I created .key file and added it in the same dir and I receive the following error
[SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN
I'm using a wildcard CA certificate using the official DNS of my company and It is the same I used in the base deployment.
How can I solve this issue?
Thank you in advance
Fabio
RaviNarayanan
Hi Fabio,
Thanks for this posting. Please let us know if you were able to make progress. Can you please indicate if this is an installation is on English or a non-English locale?
Thanks
Ravi
