Error font when edit data on Feature Service
516
6
a week ago
GISUser1619_Nguyen
Hi!
 I get issue when I edit text field it become error font after few second with ArcGIS Pro 3.7 and Enterprise 12
And if run Append to Feature Class in Geodatabase, font ok in picture 1
But when I run append to Feature Service with same data, Vietnamese Font get error in picture 2
Any one have solution for this issue? I think it related to ArcGIS Enterprise configuration
Thank you!
Teresa-AZ
Hi Nguyen,
Here is what I know:  The Append Tool to a GDB changes the "physical" storage (on your machine or a server or some type of local server.)  If you use the Append Tool on a feature service, then it requires "web edits" such as ApplyEdits operation. In this Esri Community, I did see this one which may help: https://community.esri.com/t5/arcgis-pro-questions/appending-data-to-a-feature-service-via-arcpy-or/... and I am sure you already looked at the Esri Pro stuff like this: https://pro.arcgis.com/en/pro-app/3.4/tool-reference/data-management/append.htm   I wish I could be more helpful!
GISUser1619_Nguyen
Thank you for your reply,
But my issue not only for Append tool, even I edit any Text field in Feature Service, It also become font error after few second. I think it related to ArcGIS Enterprise configuration for Font.
Teresa-AZ
Gotcha.  I would check to be sure the correct font is installed in AGE.  Esri has documentation about it.  It presume it would indeed need to be installed on the AGE server.  Best of luck!
GISUser1619_Nguyen
Hi @Teresa-AZ
Thank for your reply, it look like some thing go wrong when install Arcgis Enterprise. I already log this case to Esri support, seem like need review more detail in technical.
GlenterpriseUK
Hi @GISUser1619_Nguyen,
I hope you are well.
Could you please log a case with Esri Technical Support so this can be looked into in more detail?
Before reaching out, it would really help if you could check whether the issue can be reproduced directly within ArcGIS Enterprise, without involving ArcGIS Pro. If it does not occur there, we will likely need to focus the investigation on ArcGIS Pro instead.
Regards,
Glen
GISUser1619_Nguyen
Hi @GlenterpriseUK
Thank you for you reply and concern about this issue. I already log case on Esri technical support ID: 04177325. Please help to review it, thank you so much!
