Error executing tool. Export Web Map : ERROR 000800: The value is not a member of MAP_ONLY.
5875
12-21-2022 09:07 AM
mikeytes
ArcGIS Pro: 3.0.3
ArcGIS Enterprise Server (Linux): 10.9.1
I followed the following tutorials to create a custom print service so we can utilize additional templates for printing web maps.
https://enterprise.arcgis.com/en/server/latest/publish-services/windows/tutorial-publish-additional-...
https://www.youtube.com/watch?v=TUHg7rgTRn4
However, the export fails every time and we receive the following error. Error executing tool. Export Web Map : ERROR 000800: The value is not a member of MAP_ONLY.
As you can see, the Layout_Template parameter contains an array with two values: Layout and MAP_ONLY. I've published the ExportWebMap service with both MAP_ONLY and Layout as the default value, but haven't had any luck.
Has anybody experienced this issue? It has been such a pain getting custom print templates to work with our web maps on Portal!
In this session, techniques will be described and demonstrated for exporting high quality maps from web applications. We will cover creating printed PDF documents, printing to scale, leveraging ArcGIS Pro layouts, displaying all content on the map, modifying the map content during the export ...
ttimmerman_nes
Hi @mikeytes ,
We ran into this issue with a client a couple months ago. We ended up using an ArcGIS Pro 2.9 client to publish the service and it worked fine. It seems print services published from ArcGIS Pro 3 are incompatible with ArcGIS Enterprise 10.9.1. For reference: Solved: Re: Custom Print Service Failing - Esri Community
Hope this helps.
ttimmerman_nes
Hi @mikeytes ,
Hope this helps.
mikeytes
Thank you! We thought this was fixed with the release of 3.0.3. But apparently not! ArcGIS Pro 3.0.x is meant to run collaboratively with ArcGIS Enterprise 11. For now, we have to downgrade to 2.9.
