Error accessing published attribute data from a SQL database to Portal 10.9.1
1285
07-07-2022 07:25 AM
Reymond_Martínez
Hello, I hope you can help me with this problem when viewing the data of the attributes of some tables that I publish from a SQL database to Portal 10.9.1, during the workflow it does not give me any errors and everything is published correctly but when trying to access the data inside the tables through the portal I get a box of cannot access data.
Please review the support article for this issue https://support.esri.com/es/technical-article/000016280
I proceeded to review all the possible causes and none is my case since everything is correct I do not have /NUll values ​​or special characters #@$ in the data of the tables.
