I recently created a model to be published as a geoprocessing service which will take a number of feature classes and perform several processes and rewrite them back to our server. When I run the model, everything works correctly and I can publish the service with no issues.
The issue is that when I run the process on our server, it fails and writes the following error code in the server log:
Error executing tool. Land_Type_Acres Job ID: jd17fece367bc42e69c34a27e144faade : ERROR 000210: Cannot create output c:\arcgisserver\directories\arcgisjobs\assessing\ltacreage_gpserver\jd17fece367bc42e69c34a27e144faade\scratch\scratch.gdb\LandType_Scratch\temp_int_woodland Failed to execute (Intersect (2)). Failed to execute (LTAcreage). Failed to execute (Land_Type_Acres). |
I have attempted to work with the environment settings in the tool to change the scratch.gdb, have tried making the model work in a local geodatabase only, and allowed data store access to the arcgisserver folder. Nothing seems to work.
Hi Christopher,
How many machines are in this ArcGIS Server site? Is the account that is running the ArcGIS Server Windows Service(s) a local acccount or a domain account?
Jacob,
There is only one machine and it appears to be a domain account that is running the ArcGIS Server Windows Service.
Thank you,
Chris
