Error 001369 ArcGIS Enterprise Linux
4831
9
02-19-2019 02:22 PM
RobertCrawford1
Hey Everyone,
I'm getting the error below
ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition). Failed. Failed to execute (PublishServiceDefinition). Failed to execute (Publish Portal Service).
I've done CHOWN on the arcgis install folder to ensure permissions
Also, I have a database registered
I'm not really sure why I'm getting this error
JonathanQuinn
Esri Notable Contributor
Do you see anything in the Server logs? You can set the logs to DEBUG and republish if you want to get the most out of them. When publishing fails, it should log something within the Server logs.
RobertCrawford1
com.esri.discovery.DiscoveryException: Service Hosted/FD4_PlanningZones/MapServer not found at com.esri.discovery.DiscoveryAGSConnector.throwServiceNotFound(DiscoveryAGSConnector.java:611) at com.esri.discovery.DiscoveryAGSConnector.getServiceConfig(DiscoveryAGSConnector.java:434) at com.esri.client.featureserver.FeatureServiceClient$1.call(FeatureServiceClient.java:247) at com.esri.client.featureserver.FeatureServiceClient$1.call(FeatureServiceClient.java:244) at com.esri.client.util.ClientUtil.passThruCache(ClientUtil.java:182) at com.esri.client.featureserver.FeatureServiceClient.getAggregatedResource(FeatureServiceClient.java:244) at com.esri.client.featureserver.FeatureServiceClient.isCachingDisabled(FeatureServiceClient.java:439) at com.esri.client.app.featureserver.FeatureServerHandler.featureServer(FeatureServerHandler.java:116) at com.esri.client.app.featureserver.FeatureServerHandler.service(FeatureServerHandler.java:100) at com.esri.rf.RServlet.service(RServlet.java:121) at javax.servlet.http.HttpServlet.service(HttpServlet.java:742) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:613) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342) at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803) at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:790) at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459) at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:748)
JonathanQuinn
Are there any other errors at the WARNING or SEVERE level about the inability to publish the service?
RobertCrawford1
SEVEREFeb 19, 2019, 11:43:32 PMError executing tool. PublishServiceDefinition Job ID: j126c3767253a42b6ad18aca5bb47307d : ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition).System/PublishingToolsEx.GPServer
SEVEREFeb 19, 2019, 11:43:32 PMError executing tool. Publish Portal Service Job ID: j70b06896849b41c1877a653a6feb6d16 : ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition). Failed. Failed to execute (PublishServiceDefinition). Failed to execute (Publish Portal Service).System/PublishingTools.GPServer
SEVEREFeb 19, 2019, 11:43:32 PMERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition). Failed. Failed to execute (PublishServiceDefinition).System/PublishingTools.GPServer
SEVEREFeb 19, 2019, 11:43:32 PMDelegate job failed.System/PublishingTools.GPServer
SEVEREFeb 19, 2019, 11:43:31 PMFailed to create the service.: ERROR: code:500, Failed to create the service 'Hosted/FD4_PlanningZones.FeatureServer'. The submitted field 'st_area(shape)' does not exist in the table 'db_0m03e.hsu_cbu2s.fd4_planningzones_fd4_planningzones_clip'., Internal server error.System/PublishingToolsEx.GPServer
SEVEREFeb 19, 2019, 11:43:29 PMCore server call to create service failed (/admin/createService).System/PublishingToolsEx.GPServer
SEVEREFeb 19, 2019, 11:43:29 PMFailed to create the service 'Hosted/FD4_PlanningZones.FeatureServer'. The submitted field 'st_area(shape)' does not exist in the table 'db_0m03e.hsu_cbu2s.fd4_planningzones_fd4_planningzones_clip'.
JonathanQuinn
Sounds like a bug. Do you have only default fields in the feature class you're publishing, (OID, Shape, etc)? If so, try to add another field and publish.
You may want to reach out to Tech Support and provide your data so they can check whether they can reproduce it as well.
RobertCrawford1
That would be correct.
RobertCrawford1
It would appear that adding the field resolved the issue. Should I file a bug or is it a known issue?
JonathanQuinn
You may be running into this:
BUG-000119454 - Publishing a line feature class to Portal from ArcGIS Pro with only the default fields in the feature class fails
If you want to confirm or be attached to the bug, contact Tech Support and they can work with you on that.
HarroldSompotan
Might want to check out theses Knowledge Articles below if you have not seen them yet:
-ERROR 001369: Failed to create the service : https://support.esri.com/en/Technical-Article/000016577
-Service is currently being configured by another administrative operation:
https://support.esri.com/en/Technical-Article/000015549
Also to eliminate the issue coming from the Arcgis Serer side, please check to see if the Arcgis Server "Publishing Tools" is running via Arcgis Server Manager>System>. and see about testing a Service Definition (sd) file via Arcgis Server Manager? Publish a service definition in ArcGIS Server Manager—Documentation | ArcGIS Enterprise
