Enabling editing for bulk published feature services
10022
19
09-22-2021 01:04 PM
tigerwoulds
We are running ArcGIS Enterprise 10.8.1. I followed this doc here to bulk publish around 50 feature services: Publish layers in bulk from a user-managed data store—Portal for ArcGIS | Documentation for ArcGIS E...
As the doc states, editing is not enabled by default. Is there a way (either through Portal/Server Manager or using Python) to go into the service properties and enable editing?
LongDinh
I forgot parenthesises in my print statement. It is currently printing the method object and not the returned value. It should be:
print (response.json())
That means the request was successful, however, in ESRI's REST service implementation, the response from the service will return a message in JSON format. You will likely see an error property in the returned JSON.
For other status codes, you can look at this.
tigerwoulds
It worked like a charm, no errors. Thank you very much!
Next goal is to apply this workflow to over 100 services in a folder on Server Manager so I can make the same edits to every service within that folder. Thank you again for your help thus far.
tigerwoulds
Hi @LongDinh
For some reason, my script is throwing an error when submitting the POST. I am building the JSON file programmatically (since I have 100's of services), but my code sees the JSON file as invalid.
{'status': 'error', 'messages': ["A JSONObject text must begin with '{' at character 1
  • The JSON file is does start with the {
  • I have validated it using an online editor
  • I can copy the JSON from the file and submit it through the MapServer/edit endpoint and it is successful.  Any ideas why I cant POST the JSON file?
LongDinh
Hi @tigerwoulds ,
The variable json_file is a path and not a JSON object hence the input parameter throws a 'does not begin with {' error.
I think your payload on line 100 should be:
payload = {
 'f':'json',
 'service': service_json,
 'token': token
tigerwoulds
Yes good catch, I missed that. Unfortunately I still get the same error
LongDinh
Try converting the service_json to a json string like:
payload = {
   'f': 'json',
   'service': json.dumps(service_json),
   'token': token
Hopefully it throws a different error.
tigerwoulds
@LongDinh unfortunately, same issue BUT I was able to figure this out using a slightly different method from this example. I converted this to python 3 and replaced the httplib/urllib pieces with the functions from the 'request' library for python 3 and everything is worked as expected. Including the payload as you described initially was key to get this working.
I can now loop through a folder on my GIS Server and update properties/capabilities for all services in the folder.
Big thank you for your help again.
LongDinh
Awesome work! Glad to hear you reached a solution 🙂
MichaelSnook
@tigerwoulds ..I am looking to do the exact same thing but I'm getting a bit lost on the upgrade.  Can you share your working Python3 script by chance?  Thanks!
DrewDowling
This seems to still be an issue in 2025, you can't use the ArcGIS python API to modify referenced feature services, or at least I couldn't get it working.
Here some code I wrote to use the ArcGIS Server admin rest endpoint instead. It updates the capability of all feature services in a folder to add Extract to the default Query capability. Hope it helps someone.
from arcgis import GIS
import requests
import json
domain = 'gis.domain.org'
folder = 'MyServerFolder'
# login to GIS
gis = GIS(url="https://gis.domain.org/portal/home", profile='sangis_portal_aiteadmin')
token = gis._con.token
# Get a list of services from ArcGIS Server
# from a specific folder
gis_servers = gis.admin.servers.list()
print(gis_servers)
# Assuming a single server for simplicity
server1 = gis_servers[0]
damoa_services = server1.services.list(folder=folder)
for service in damoa_services:
    # Get the service definition
    service_def = requests.get(f'{service.url}?f=json&token={token}').json()
    service_name = service_def['serviceName']
    # Loop through the service extensions to find the FeatureServer extension
    i=0
    for ect in service_def['extensions']:
        if ect['typeName'] == 'FeatureServer':
            print("Enabling Feature Access capabilities...")
            print(f"original capabilities: {service_def['extensions'][i]['capabilities']}")
            # Update capabilities by editing the service definition
            service_def['extensions'][i]['capabilities'] = "Query,Extract"
            print(f"Updated capabilities: {service_def['extensions'][i]['capabilities']}")
            # Construct the URL for editing the service definition
            # This URL is specific to ArcGIS Server REST API
            edit_service_url = f"https://{domain}/arcgis/admin/services/{folder}/{service_name}.MapServer/edit"
            try:
                payload = {
                    'f': 'json',
                    'service':json.dumps(service_def),
                    'token':token
                # Make the POST request to update the service definition
                response = requests.post(url=edit_service_url, data=payload)
                # Check if the request was successful
                # This doesn't work, 200 is returned even if the update fails
                # Check the responce conteent instead
                if response.status_code == 200:
                    print("Capabilities updated successfully.")
                else:
                    print(f"Failed to update capabilities: {response.text}")
            except requests.exceptions.RequestException as e:
                raise e
            i=0
            break
        else:
              i += 1
