Editing feature class in portal but can't see my changes in my database
994
07-17-2018 06:02 AM
StéphanieBeauregard1
I create a new database  with related features class and tables. I can publish and edit my datas in portal, they keep their changes there, but I can't see that changes in my database. Did I forgot something in the setting of my new database? I restart my services and ArcGIS but no changes appear. Thanks for help!
JakeSkinner
Esri Esteemed Contributor
Hi Stephanie,
What application did you use to publish your data, ArcMap or ArcGIS Pro?
In ArcMap, if you published data to 'My Hosted Services' this will make a copy of the data and place it in the ArcGIS Data Store.  You will want to publish the data to ArcGIS Server.
In ArcGIS Pro, if you chose the option to 'Copy all data', it will make a copy of the data and place it in the ArcGIS Data Store.  You will want to check the option to 'Reference registered data'.  This will publish your data to ArcGIS Server.
Also, when publishing data to ArcGIS Server, you will want to make sure you register your geodatabase with ArcGIS Server:
Register your data with ArcGIS Server using ArcGIS Desktop—Documentation | ArcGIS Enterprise
Hi Jake
I’m using ArcGIS desktop to publish on the portal. I found a part of the answer but I didn’t resolve the entire problem.
I create a new database on my SQL instance and when I edit the FC/table in this database on the portal, the savings are made in my other database on the same instance??? It looks like it create new fc/table in my other database ?!? Maybe I did not connect correctly my new database to server?
Do you have any idea?
(Here you see the file created in my old database on the same instance)
De : Jake Skinner <geonet@esri.com>
Envoyé : July 17, 2018 10:56 AM
À : Stephanie Beauregard <SBeauregard@ecrc-simec.ca>
Objet : Re: - Re: Editing feature class in portal but can't see my changes in my database
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from Jake Skinner<https://community.esri.com/people/jskinner-esristaff?et=watches.email.thread> in Esri Technical Support - View the full discussion<https://community.esri.com/message/785277-re-editing-feature-class-in-portal-but-cant-see-my-changes-in-my-database?commentID=785277&et=watches.email.thread#comment-785277>
