Editable Feature Service
10693
21
04-10-2013 06:42 AM
JoshObrecht
I have published a Feature Service, however am unable to edit it. I try editing in ArcMap and receive two messages: "No editable layers" and "The workspace containing this data cannot be edited." I have registered the data source and versioned the geodatabase. What else may be the issue?
RobertBorchert
Honored Contributor
When you published the data did you enable editing?  Also do you have permissions to edit the data.
JoshObrecht
Editing is shown under the capabilities for the layer.
Does the permission need to be the ArcGIS Server admin on the server with SDE?
JillianPenney
How are you consuming the service in ArcMap, is it through a ArcGIS Server user connection?
JoshObrecht
That is correct.
nicogis
What's the license ArcMap (basic, std or adv) ? you can use std or adv for editing feature service
JoshObrecht
I am using Advanced
JillianPenney
Ok, so in order to edit a feature service in ArcMap you need to make a local copy for editing and then synchronize the local edits with the server when you're finished editing. To do this:
  1. Drag the feature service onto the Data Frame
  2. Switch to the 'List by Drawing Order' view in the table of contents
  3. Right click on the group layer and go down to 'Edit Features'
  4. Select 'Create Local Copy for Editing'
  5. You may then make the edits required.
  6. When you're satisfied with your edits and ready to synchronize them back, right click the group layer again>Edit Features>Synchronize Local Edits with the Server
  7. This will apply the edits you've made to the features in the feature service
For further information, you can read the documentation here:
http://resources.arcgis.com/en/help/main/10.1/index.html#//01m60000000s000000
Hope this helps!
Jill
JoshObrecht
I'm getting an error message.
"A local copy could not be created. Bad syntax in request."
JillianPenney
Hmm... what kinda of data are you using? Does it have GlobalID's or attachments?
