Hello,
I have a feature service which references an Enterprise gdb feature class. I created a new domain, applied it to one of the fields in the feature class, and overwrote the service (Enterprise 11.1). Despite everything saving correctly and publishing correctly, I'm not able to select from the values in the domain when I go to edit the feature in a web environment. Also, the REST endpoint does not show the coded values in the attribute info.
This has been kind of a long running problem - sometimes a similar issue will get fixed if I overwrite a service like 10 times, and other, like now, I just can't get the changes to stick.
Hi all,
Just reporting a similar issue in case this solution works for someone else.
I have two services from the same feature class, one is editable for admins and the other is read-only. They are referenced from two different SDE connections (Edit/Read-only) to the same database, so they both point to the same data. With a republish, the editable version domains updated and the read-only did not.
ArcGIS Pro 3.4.0, Enterprise 11.1.
All the best,
Glen
Thank you. Unassigned domains at DB level, republish service. Add domains back and republish worked for me.
ArcGIS Pro 3.3, Enterprise 11.3, SQL server
I had this problem. I stopped and restarted the service, then my coded values were visible in the service.
Genuinely surprised that this thread still does not have a marked answer and that no one else has acknowledged your answer here.
I encountered the same issues with feature services referencing data published from a SQL Server enterprise GDB in ArcGIS Pro 3.4.3 to Enterprise 11.3. I've observed this behavior not only with domains but with also an attribute rules; in the latter case, my organization republished a feature service to include an attribute rule that auto-populated an Elevation field, but when modifying the service the Elevation field would always auto-populate to zero.
Stopping and restarting the service resolves this issue. (Coded values are now visible, that attribute rule auto-populates correctly, etc.)
Having this same issue. Published a shared referenced service from SQL Server in Arc Pro 3.4.3 to Enterprise 11.4
Stopping and restarting the service didn't do anything at all. No domains shown in QueryDomains in the REST endpoint. Pulling the FC into Pro showed the domains just fine. Re-publishing the service multiple times had no effect.
Found this thread, and changing to a dedicated instance finally showed the domains. Once they showed up, I could change back to a shared instance, but every time there is an update to any of the domains, it has to be switched to dedicated & back.
This is really frustrating to say the least, because for this particular service, I will need to setup a process that updates the domain nightly based on another table. This will obviously add a lot of overhead to that automation.
I'm still on 11.1, and I just wanted to follow up and note that I also notice the same behavior when re-publishing after updating a relationship class. I republished after the changes, but it didn't update the relationship values as shown in the REST relationship details. I had to close Pro, re-open, and re-publish, and it updated after that. I'm thinking this is the same symptom as with domains where it is sometimes not passing the updated service definition values for whatever reason when things are republished.
On Pro 3.3 / Enterprise 11.3, I had the same problem where I couldn't see domain changes on a shared instance service until I went to dedicated, but then couldn't get those changes to stick when I switched it back to shared. In my case, though, changing the Enterprise site-level schema lock setting to disable "Lock database schema for shared instances" and then restarting the problem service resolved it for me (in that link, scroll down to the "Modify the schema lock setting for shared instance map services" section.)
Interestingly, I'm pretty sure I published the service from Pro with "Enable schema locking" turned off (Share As Web Layer --> Configuration tab --> Configure Parameters button --> Properties --> Advanced), but it seems like the site-level setting to lock the schema overrode that choice. So if your organization allows the site-level schema lock setting to be disabled for shared instances, it might be worth trying that out.
ArcPro 3.5, Enterprise 11.5: I deleted all the locks on my feature class and then republished and that worked. I did not turn off "enable schema locking" in the configuration when I republished. Previously had tried restarting the service to no avail. I was ready to try your suggestions but this worked first.
Hi all,
Adding my two cents to this thread regarding how I fixed my domains not updating in Views when updating the source Feature Layers running an Enterprise 11.4 on Azure and Pro 3.4.3.
After updating the source Feature Layer (adding additional values to a domain) I noticed the View was not updating with the new Domain. I can confirm `propagateVisibleFields` was True in the layer properties (reference).
I noticed when overwriting the layers that my domains got new names upon publishing (updated_domain_logs.png).
These new domain names weren't being propagated through to the View layer.
After, I manually set the updated View field to mimic the source Feature Layers field. This worked fine but removes the inheritance from this field within the view layer. After going into the Views field (field_inheritance.png) I was able to reenable inheritance which correctly sourced the updated domain from the source layer.
Hopefully this helps someone.
I have been having the same problem with ArcGIS Pro 3.6 and ArcGIS Enterprise 11.5. The first time I encountered the issue, stopping and starting the service worked.
The second time, neither republishing or stopping/starting the service would get the domain to update.
It wasn't until I changed the Instance Type in ArcGIS Server Manager from Shared to Dedicated that the domain updated. (I changed it back to Shared afterwards).
Related bug: https://support.esri.com/en-us/bug/updates-to-the-domain-values-of-a-field-are-not-reflect-bug-00013...
