Hi Everyone,
We are running into an issue configuring SAML authentication (using Azure Entra ID) for our Disaster Recovery (DR) environment.
Deployment Setup: Production and DR (Disaster Recovery) environments — both are exact replicas of each other.
ArcGIS Enterprise Version: 11.5
OS: Windows Server
Deployment Type: High Availability (HA)
Web Context URL: Identical on both Prod and DR
SSL Certificates: Identical on both Prod and DR
To ensure members can seamlessly sign in after a failover event to our DR environment, we are configuring matching SAML certificates across both identical environments.
We followed the guidelines in the Esri documentation:
Reference: Organization-specific login considerations for geographic redundancy
Configured SAML Logins: Set up SAML authentication on both the Prod and DR environments using the same Federation Metadata URL.
Exported/Imported SAML Certificate: Exported the SAML certificate from Production and imported it into the DR environment.
Enabled Encrypted Assertions (Prod): Turned on Encrypted Assertions on the Production environment. ------> Working as expected.
Enabled Encrypted Assertions (DR): Turned on Encrypted Assertions on the DR environment. ------> Fails.
When enabling Encrypted Assertions on the DR environment, authentication fails.
Has anyone encountered this behavior or can point out if we are missing any specific configuration steps for replica environments in Entra ID or ArcGIS Enterprise?
Thanks in advance for your assistance!
Regards,
Ayush
Hello @AYUSHYADAV ,
Since Production is working and DR only fails after enabling Encrypted Assertions, I would probably focus first on the SAML encryption certificate side rather than the general SAML setup.
A few things I would check:
My thinking is that encrypted assertions depend on Entra ID encrypting the assertion with the public certificate, and Portal then needing the matching private key to decrypt it. So even if Prod and DR look identical from the outside, a missing private key or a certificate mismatch in DR could cause this kind of issue.
I would start by comparing the Production and DR SAML metadata side by side, especially the encryption certificate section, Entity ID, and ACS URL. If those look correct, then I would check whether the DR Portal actually has the matching private key available for decryption.
Hi Archit,
Thanks for your reply. Here are the answers and details to your questions:
Answer: Yes, it works as expected after disabling Encrypted Assertions.
Answer: Could you guide us on how to verify if the private key was included during the import?
Below are the exact steps we followed:
Log in to the Production portaladmin endpoint.
Go to Machines > SSL Certificates > samlcert > Export.
Log in to the DR portaladmin endpoint.
Go to Machines > Machine 1 > SSL Certificates > samlcert > Delete.
Go to Machines > Machine 2 > SSL Certificates > samlcert > Delete.
Go to Machines > Machine 1 > SSL Certificates > Import Root or Intermediate > Import the samlcert file exported from Production.
Go to Machines > Machine 2 > SSL Certificates > Import Root or Intermediate > Import the samlcert file exported from Production.
Note: We did not use "Import Existing Server Certificate" because it prompts for a password, and we do not have the password for this SAML certificate.
Answer: Yes, it is available and imported on both machines.
Answer: Yes, they are 100% identical.
Answer: Yes.
Answer: Yes.
Answer: Yes, it was saved and we restarted the DR Portal machines.
Answer: Yes, please see the attached screenshot of the logs.
Answer: We do not have access to the Azure Entra ID sign-in logs.
I agree with your analysis: encrypted assertions require Entra ID to encrypt with the public key, and Portal requires the matching private key to decrypt it. Because we imported via "Import Root or Intermediate", the private key was likely omitted, which aligns with what the portaladmin logs indicate.
Could you help us verify if the private key is present on the DR certificate, or advise on the correct procedure to export/import the private key?
Ayush
Hello @AYUSHYADAV ,
Thanks for sharing the details and the Portal log screenshot.
The log message seems important here:
Invalid_SAMLResponse: Unable to login using Idp. Error validating encrypted Assertion Unable to decrypt without a KEK
The lower log entry also says:
Exception in signIn using saml Unable to login using Idp. Error validating encrypted Assertion Unable to decrypt without a KEK
Since DR SAML login works when Encrypted Assertions is turned off, it looks like the general SAML flow is likely working. The Entity ID, ACS URL, metadata, and basic Entra configuration may be okay. The failure seems to happen specifically when Portal needs to decrypt the encrypted assertion.
Looking at the steps you followed, the part I would focus on is this:
You imported the Production samlcert into DR using Import Root or Intermediate.
From my understanding, that option is meant for importing root or intermediate CA certificates. It would not normally be the path used to make the DR Portal use the samlcert as the active SAML encryption/decryption certificate.
For this specific DR SAML scenario, I would follow Esri’s geographic redundancy documentation closely:
Disaster recovery and replication | ArcGIS Enterprise on Windows and Linux documentation
In the Organization-specific login considerations for geographic redundancy section, Esri lists this SAML workflow:
So I would try that documented path rather than importing the certificate as Root or Intermediate.
For the private key side, this Esri documentation may also help:
Import a certificate into the portal | ArcGIS Enterprise on Windows and Linux documentation
That page notes that when importing an existing server certificate, the certificate and its associated private key must be stored in PKCS#12 format, such as .p12 or .pfx. That also explains why Import Existing Server Certificate asks for a password.
This Esri Support article for encrypted assertions with Microsoft Entra ID may also be useful for comparing the Entra token encryption side:
Create a Certificate and Enable SAML Encrypted Assertions with ArcGIS and Microsoft Entra
Since you mentioned that you do not have access to the Azure Entra ID sign-in logs, it may be worth checking this with your Entra ID admin as well. They can help confirm whether Entra is issuing the SAML response successfully, whether encrypted assertions are enabled against the correct Enterprise application, and whether the certificate being used for token/assertion encryption matches what the DR Portal is expecting.
So I think the next thing to verify is not only whether samlcert is visible on the DR Portal machines, but whether it was imported using the correct DR workflow and whether Portal has access to the key material required to decrypt encrypted assertions.
The log message Unable to decrypt without a KEK seems to point strongly in that direction.
Hope it helps!
