Default scale visibility hosted image service
3097
06-06-2019 05:02 PM
Sergio_Galindo
I'm starting to work with a Raster Analytics cluster and I've noticed that every time I run a raster analytics function, the resulting hosted image service is shown only up to certain scale level. If I zoom out beyond, it just stops being drawn on the map (it doesn't matter if I'm in the portal map viewer or in ArcGIS Pro).
I attach a couple of screenshots to better clarify my point.
Is there any way I can set (prior executing a raster analytics function) up to which scale will the resulting hosted image service will be shown?
Can I modify somehow that setting in an existing hosted image service (created as a result of a previous raster analytics function execution)?
Thanks for your help!
