Creating the geodata service failed.
3213
02-12-2016 08:29 AM
MohammaM_Pirooz
I have two geodatabases (for local and arcgis server). when I try register them with ArcGIS Server 10.3 with geodata service capability, I get this error message:
I get guide follow link (
Prepare your local enterprise geodatabase for publishing topic
Tutorial: Perform web editing using replicated data from an enterprise geodatabase—Documentation | A...
I have Windows 10-64 bit, SQL Server 2008, RAM 4GB, CPU Core i5, HDD 500 GB.
Are there anyone help me?
Thanks a lot.
JakeSkinner
Esri Esteemed Contributor
Hi Mohamma,
Are you running ArcGIS Server 10.3 or 10.3.1?  ArcGIS Server is not supported on Windows 10 until 10.3.1:
ArcGIS for Server system requirements—Installation Guides (10.3 and 10.3.1) | ArcGIS for Server
MohammaM_Pirooz
I installed version 10.3 . I already had Windows 7 that ArcGIS Server was installed in it and I upgrade it to win 10.
I see system reqirments. My hardware is match with ArcGIS for server system requirements. I have to use win 10.
Do you think that problem is from my OS?
JakeSkinner
Most likely if you are using 10.3.  Are you able to upgrade to 10.3.1?
MohammaM_Pirooz
Hello Jake!
I'm sorry. My English language is not very well. Yes, I have installed ArcGIS for Server version 10.3 and I cannot upgrade to 10.3.1.
