I am trying to migrate/clone layers from one Enterprise installation to another. The cloning seems to work; the specified folder is created and the item is there. However when I try to open it, I get a prompt to log into the source as if the item wasn't cloned but just referenced/linked. The notebook also throws error code 498, but that might be the same issue. What's the problem here? Here's the whole notebook:
Also trying to move a scene throws no token error but as expected it fails, just differently, as well.
Hi @LR2, there is a attribute in the clone_items method called copy_data=False try setting it to True.
Regards
Henry
Thanks, unfortunately that seems to do nothing, at least the error is the same as above. I followed this instruction video, which does not mention the copy method at all. Perhaps it should be reviewed if the shown methods actually work.
These instructions are also wrong: https://support.esri.com/en/technical-article/000022252
See "full script" at the bottom. Despite giving it a specific item ID, the script finds 45 items (but displays only one - the item with the specified ID). Then it throws 45 errors and finishes without having copied anything.
45 items will be cloned. See the list below:
can only concatenate str (not "builtin_function_or_method") to str
The function has completed
