Clone hosted layer from one Portal to other with Data
767
09-04-2018 10:08 AM
GirishYadav1
Is there a way to create a clone of a Hosted layer from one ArcGIS Portal 10.6 to another? I also want to move layer's data.
Thanks!
JonathanQuinn
Esri Notable Contributor
You can export the data into different formats so you can upload the data back into the new Portal:
Use hosted layers—Portal for ArcGIS | ArcGIS Enterprise
You can also set up collaboration to do this:
About distributed collaboration—Portal for ArcGIS (10.6) | ArcGIS Enterprise
About sharing feature layer data as copies—Portal for ArcGIS (10.6) | ArcGIS Enterprise
