Check if the user logged in to ArcGIS Online or Portal
2182
04-30-2020 02:38 PM
AhmadSALEH1
Hi all,
Is there a way to check if the user logged in to ArcGIS Online or Portal in Python API
I have a script that publishes zipped shp files to my portal, but before publishing, I would like to check if I am logged in and authenticated to publish
for now, I am using gis.users.me  which returns None if am not logged in, but looking for something different than this
from arcgis.gis import GIS
gis = GIS()
print(gis.users.me)‍‍‍
Thank you,
Ahmad
Ofir_Mazor
There is still no straigth forward approch for this but I think I found a work around by getting the current user role in the portal information.
If the user is not signed-in the value in the role key will be empty string (''). Once the user is signed-in, it's role will be set in the portal info dictionary.
from arcpy import GetPortalInfo, GetActivePortalURL
def portal_sign_in_check() -> None:
    portal_info: dict = GetPortalInfo(portal_URL = GetActivePortalURL())
    if portal_info['role'] == '':
        print('User is not signed-in to portal')
    else:
        print('User is signed-in to portal')
Example of the portal info dictionary when the user is not signed-in:
{'SSL_enabled': False, 'portal_version': 9.2, 'role': '', 'organization': 'My Organization', 'organization_type': ''}
Example of the portal info dictionary when the user is signed-in:
{'SSL_enabled': True, 'portal_version': 9.2, 'role': 'org_admin', 'organization': 'My Oraganization', 'organization_type': ''}
Tags (1)
