Certificat problem for collaboration between 2 arcgis enterprise
2302
02-08-2022 01:26 AM
kvin
I have an Arcgis enterprise 10.8 under windows.
I would like to collaborate with another arcgis enterprise.
I imported the certificates of the other collaboration in the portaladmin of my arcgis web server, however when I accept the invitation response of the collaboration I have the following message:
"Invalid SSL certificate found. PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target"
"Collaboration invitation response validation failed for file 'collaboration-topo.vdl.lu.response' for collaboration with name 'Collaboration VdL-CGDIS', id '63a4ffb851cc4e6aa8ee941b6f343fb1'. Failed to validate SSL certificate for 'https://topo.vdl.lu/portal109'."
What is the format of the certificates I need to import from the other argis enterprise.
Is it in .cer, .crt format?
Kind regard
Sakib_Meharan_Siddiquei
the organization Portal does not trust the SSL cert on the Host. The SSL certificate must be trusted before the invitation can be accepted.
Regards,
Sakib
kvin
How do you do this on arcgis web server ?
Is there a specific command ?
"The SSL certificate must be trusted before the invitation can be accepted" ?
Regards
Maybe I expressed myself wrong, there is no specific command. That I meant is to make sure the Certificate is Trusted in the opposite Portal, before sending the request, only then accept the invitation from the first Portal.
Regards.
kvin
I added the url to collaborate in NoProxyHost.
Thanks for your help.
