Dashboard Chart Filter Not Working 10.9.1
598
02-14-2022 07:38 AM
mpboyle
Honored Contributor
We have noticed since updating to Enterprise 10.9.1 charts do NOT correctly filter features within a map in dashboards if the chart uses the "Split By" option.
We built a dashboard in 10.9 that produces a bar chart showing inspection counts per day per inspector.  Users could click on a particular inspector for a day and the map would filter the features.  This no longer works at 10.9.1.  When users click on a column, all points are removed from the map in the dashboard.
If I create the same chart WITHOUT the split by option, the map filters features correctly.
The service we are using is published to ArcGIS Server and resides in an enterprise (Sql Server) geodatabase.
