Can't set up Web Adaptor to use HTTP
5440
11
06-18-2020 01:51 PM
by Anonymous User
Not applicable
I have 2 VMs set up in Azure -- one hosting ArcGIS Server 10.8, and the other hosting ArcGIS Web Adaptor 10.8.
I was able to configure ArcGIS Web Adaptor for ArcGIS Server using HTTPS. Now, I want to configure it using HTTP (to access ArcGIS Server at http:<internal DNS name>:6080/arcgis). However, it seems that Web Adaptor is still trying to force the connection to use HTTPS.
When I tried to configure the web adaptor using the web interface, and click to configure a GIS server:
the browser is directed to https://webadaptorhost/server/webadaptor/server:
If I manually change it to use http, I get to the configuration page. When I try to configure the web adaptor
I get the following error message:
If I try to configure the web adaptor using the ConfigureWebAdaptor utility, it looks like it's trying to force HTTPS
Port 6080 is open on the Server machine.
DerrickWong
Hi Jonathan Bailey
Sorry, I am not following. What changes are you making to AGS that requires regression testing if not an upgrade?
Regards,
Derrick
by Anonymous User
Not applicable
Hi Derrick,
I was suggesting that perhaps Esri is missing some regression tests since something that works in ArcGIS 10.7.1 does not work in ArcGIS 10.8.
Jon.
