Can I create a collaboration from arcsde reference feature service to a local hosted read only copy?
1825
02-13-2019 03:50 PM
JaredYost3
The only way I can seem to get collaboration copy to work is if I select copy all data during the  generation of the source feature service.  If I copy all of the data than any web edits to the feature will not propagate to the arcsde server. the edits apply to a local hosted copy on the portal.
So long story short is there a way to get it to copy from a reference feature service?  I am basically trying to create an automated read only version for public view vs a in house editable view that points to the sde database.
by Anonymous User
Not applicable
Hi Jared,
Yes you will be able to share the feature layer (from your Enterprise GDB) as a copy to Portal 2, you just need to ensure the feature layer is sync-enabled before publishing from Pro to Portal.
See the documentation below:
Share feature layers from an enterprise geodatabase—Portal for ArcGIS (10.6) | ArcGIS Enterprise
Hope this helps!
Joel
by Anonymous User
Not applicable
Hi Jared,
Hope this helps!
Joel
JaredYost3
Thank you Joel for the response, I was able to get the workflow finally. My battle now is with getting it to work with attachments.  From what I can tell I have followed all the guidance.  Gloabal IDs etc.
Do you think that workflow will work with attachments?
Thanks again
