cachingTools, cache creation, pooling and parallel work
1126
08-28-2020 08:23 AM
RiccardoKlinger
Hi folks,
we are running on a virtual server with 12 physical cores/ 24 virtual cores and we are not seeing any relevant perfomance boost after upgrading from a 8/16 core setup yet.
We are setting the MAX_Number of instances for the cachingtools service according to this ressource to 22 cores (it should be 25 ... 2n+1) to let some space for parallel threads on  the machine.
With regard to the best practice paper we are now also setting the MIN_Number to 22.
Running the tile cache creation on my desktop I saw, that it was running level 0 with one bundle eg 1 core, then going up to level 6 and still only one bundle and one core utilized. in level 7 it was creating three bundles and utilized three cores at that time. So there was no parallelization in the lower zoom levels.
On Desktop I was utilizing:
ManageTileCache_management
Is the described behaviour also occuring on the server side running the creation of tiles using this arcpy command:
ManageMapServerCacheTiles_server
Here is the order of folder creation (right column: creation time):
some insight into cache creation:
Despite the need to render like hell as not all tiles are created, the server manager shows that not all instances are "active" (screenshot from a test system with 8 instead of 22 cores):
Sometimes it peaks at 6 instances but mots of the times it is showing 3...
I am looking forward your suggestions...
Best, Ric
