AWS 10.8.1 HA Portal not restarting
13697
28
08-24-2020 06:47 AM
ShanonLoughton
Hi
In AWS Ive deployed ArcGIS Enterprise 10.8.1 using Windows in HA and using ELB, both templates available here.
It works on first deployment and successful CloudFormation create-stack.
However when stopping/restarting Portal service on a given instance, or rebooting the Portal instances (either of them), they fail to restart Portal service, citing internal database not started properly, and symptoms like passwords rejected at /portaladmin login.
Here's one instance's set of logs:
Windows EventViewer
PostgreSQL : The description for Event ID 0 from source PostgreSQL cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. (repeated, initially Information class, but further back is Error class)
Portal: The description for Event ID 5 from source Portal for ArcGIS cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. (repeated, initially Information class, but further back is Error class)
"C:\Program Files\ArcGIS\Portal\framework\service\logs\service-error-0.log"
Mon Aug 24 13:01:13.237 UTC 2020 Exception in thread "I/O dispatcher 17"
Mon Aug 24 13:01:13.237 UTC 2020 java.lang.NoSuchMethodError: org.apache.http.ConnectionClosedException: method 'void <init>()' not found
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.nio.protocol.HttpAsyncRequestExecutor.endOfInput(HttpAsyncRequestExecutor.java:356)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.DefaultNHttpClientConnection.consumeInput(DefaultNHttpClientConnection.java:261)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.client.InternalIODispatch.onInputReady(InternalIODispatch.java:81)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.client.InternalIODispatch.onInputReady(InternalIODispatch.java:39)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.reactor.AbstractIODispatch.inputReady(AbstractIODispatch.java:114)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.reactor.BaseIOReactor.readable(BaseIOReactor.java:162)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.reactor.AbstractIOReactor.processEvent(AbstractIOReactor.java:337)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.reactor.AbstractIOReactor.processEvents(AbstractIOReactor.java:315)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.reactor.AbstractIOReactor.execute(AbstractIOReactor.java:276)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.reactor.BaseIOReactor.execute(BaseIOReactor.java:104)
Mon Aug 24 13:01:13.237 UTC 2020 at org.apache.http.impl.nio.reactor.AbstractMultiworkerIOReactor$Worker.run(AbstractMultiworkerIOReactor.java:591)
Mon Aug 24 13:01:13.237 UTC 2020 at java.base/java.lang.Thread.run(Unknown Source)
"C:\arcgisportal\logs\10.72.4.42\portal\portal-20200824.123347-12940-0.0.log"
<Msg time="2020-08-24T12:34:34,908" type="SEVERE" code="218010" source="Portal Admin" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The portal has been initialized and configured but is not accessible. The internal portal database does not appear to be running or accepting connections. Restart the portal machine or machines and if the problem persists, contact Esri technical support (U.S.) or your distributor (customers outside the U.S.).</Msg>
<Msg time="2020-08-24T12:34:34,908" type="WARNING" code="218012" source="Portal Admin" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">Error at check and update urls. The portal is currently unavailable. Please contact your portal administrator.</Msg>
<Msg time="2020-08-24T12:35:12,375" type="SEVERE" code="218010" source="Portal Admin" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The portal has been initialized and configured but is not accessible. The internal portal database does not appear to be running or accepting connections. Restart the portal machine or machines and if the problem persists, contact Esri technical support (U.S.) or your distributor (customers outside the U.S.).</Msg>
<Msg time="2020-08-24T12:35:18,695" type="SEVERE" code="218010" source="Portal Admin" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The portal has been initialized and configured but is not accessible. The internal portal database does not appear to be running or accepting connections. Restart the portal machine or machines and if the problem persists, contact Esri technical support (U.S.) or your distributor (customers outside the U.S.).</Msg>
<Msg time="2020-08-24T12:35:22,903" type="WARNING" code="218014" source="Portal" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">Starting Index Service.</Msg>
<Msg time="2020-08-24T12:36:28,437" type="SEVERE" code="218010" source="Portal Admin" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The portal has been initialized and configured but is not accessible. The internal portal database does not appear to be running or accepting connections. Restart the portal machine or machines and if the problem persists, contact Esri technical support (U.S.) or your distributor (customers outside the U.S.).</Msg>
<Msg time="2020-08-24T12:36:49,886" type="SEVERE" code="218010" source="Portal Admin" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The portal has been initialized and configured but is not accessible. The internal portal database does not appear to be running or accepting connections. Restart the portal machine or machines and if the problem persists, contact Esri technical support (U.S.) or your distributor (customers outside the U.S.).</Msg>
<Msg time="2020-08-24T12:37:44,483" type="SEVERE" code="218010" source="Portal Admin" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The portal has been initialized and configured but is not accessible. The internal portal database does not appear to be running or accepting connections. Restart the portal machine or machines and if the problem persists, contact Esri technical support (U.S.) or your distributor (customers outside the U.S.).</Msg>
<Msg time="2020-08-24T12:38:09,93" type="SEVERE" code="218010" source="Portal Admin" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The portal has been initialized and configured but is not accessible. The internal portal database does not appear to be running or accepting connections. Restart the portal machine or machines and if the problem persists, contact Esri technical support (U.S.) or your distributor (customers outside the U.S.).</Msg>
<Msg time="2020-08-24T12:38:41,750" type="WARNING" code="218015" source="Portal" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">Started Index Service.</Msg>
<Msg time="2020-08-24T12:38:41,828" type="WARNING" code="217060" source="Portal" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The database server was found to be stopped. Re-starting it.</Msg>
<Msg time="2020-08-24T12:38:51,974" type="WARNING" code="217064" source="Portal" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">The web server was found to be stopped. Re-starting it.</Msg>
<Msg time="2020-08-24T12:43:09,108" type="WARNING" code="219999" source="Portal Admin" process="5948" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID=""> Failed to generate a token for user 'portaladmin'. java.lang.Exception: Server returned HTTP status code 404. Requested URL: https://10.72.4.42:7443/arcgis/sharing/generateToken</Msg>
<Msg time="2020-08-24T12:43:12,517" type="WARNING" code="219999" source="Portal Admin" process="5948" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID=""> Failed to generate a token for user 'portaladmin'. java.lang.Exception: Server returned HTTP status code 404. Requested URL: https://10.72.4.42:7443/arcgis/sharing/generateToken</Msg>
<Msg time="2020-08-24T12:43:15,819" type="WARNING" code="219999" source="Portal Admin" process="5948" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID=""> Failed to generate a token for user 'portaladmin'. java.lang.Exception: Server returned HTTP status code 404. Requested URL: https://10.72.4.42:7443/arcgis/sharing/generateToken</Msg>
<Msg time="2020-08-24T12:43:20,950" type="WARNING" code="219999" source="Portal Admin" process="5948" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID=""> Failed to generate a token for user 'portaladmin'. java.lang.Exception: Server returned HTTP status code 404. Requested URL: https://10.72.4.42:7443/arcgis/sharing/generateToken</Msg>
<Msg time="2020-08-24T12:43:31,158" type="WARNING" code="219999" source="Portal Admin" process="5948" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID=""> Failed to generate a token for user 'portaladmin'. java.lang.Exception: Server returned HTTP status code 404. Requested URL: https://10.72.4.42:7443/arcgis/sharing/generateToken</Msg>
<Msg time="2020-08-24T13:01:13,481" type="WARNING" code="217068" source="Portal" process="12940" thread="1" methodName="" machine="10.72.4.42" user="" elapsed="" requestID="">Error in the process monitor watchdog thread. sleep interrupted</Msg>
"C:\arcgisportal\logs\database\pg_log\postgresql-2020-08-24_060707.log"
2020-08-24 05:38:42 PDT: [6272]: LOG: database system was shut down at 2020-08-24 05:32:36 PDT
2020-08-24 05:38:42 PDT: [5824]: LOG: database system is ready to accept connections
2020-08-24 05:38:42 PDT: [10060]: LOG: incomplete startup packet
2020-08-24 05:38:42 PDT: [10180]: FATAL: no pg_hba.conf entry for host "::1", user "arcgis", database "arcgis", SSL off
2020-08-24 05:39:12 PDT: [12016]: LOG: incomplete startup packet
2020-08-24 05:40:12 PDT: [12196]: LOG: incomplete startup packet
2020-08-24 05:41:12 PDT: [12120]: LOG: incomplete startup packet
2020-08-24 05:42:12 PDT: [11232]: LOG: incomplete startup packet (repeated)
2020-08-24 05:42:33 PDT: [11348]: LOG: could not receive data from client: An existing connection was forcibly closed by the remote host. (repeated)
Thanks for any help.
ArcGIS Enterprise on AWS, Azure & Google Cloud Professional
Trevor_Hart
@WilliamCraft weve been told by Esri that this has been replicated and is fixed in 10.9.0 - there is a bug number; BUG-000134458
Besides trying to stop/start the servers, killing the javaw.exe process associated with Portal seems to resolve the issue - sometimes I need to do this on both servers (I think it depends which was the primary and which was the standby).
JonathanQuinn
Esri Notable Contributor
Yes, @Trevor_Hart is correct:
It's a timing problem that we're fixing in a patch:
BUG-000134458 - In some environments, the standby portal does not rejoin successfully.
Please keep on the lookout for the release of the patch within the near future.
WilliamCraft
MVP Regular Contributor
@JonathanQuinn can I assume the fix has been incorporated into the 10.9.0 pre-release version of the software?
Trevor_Hart
Depends when the build is from - my 10.9.0 pre-release was from December.
So I dont think as we only got notified of a fix for the bug last week.
JonathanQuinn
No, it's not in 10.9 pre-release but will be in final
DavidHoy
@JonathanQuinn  - will there will be a patch for this for 10.7.x/10.8.x ?
JonathanQuinn
Yes, a patch will be released for 10.8.1. This doesn't impact 10.7.1. If you see differently, please contact Support for them to investigate.
WilliamCraft
Here is the 10.8.1 patch to address this issue: https://support.esri.com/en/download/7864 (Portal for ArcGIS 10.8.1 High Availability Rejoin Patch)
KThomasson
I have this same portal Log warning of  "WARNING" code="217064" and it lead me to this article, so I have downloaded and installed the patch but it is still doing the same thing, does anyone have any advice on something I might do to try and get my site to working again.  I am able to connect to portal in the command line using telnet.
