ArcGIS Server
3824
6
02-29-2016 04:48 AM
SG
What is ArcGIS Server used for mainly? How does the ArcGIS JavaScript API work with ArcGIS Server?
JakeSkinner
Esri Esteemed Contributor
Hi SG,
Simply put, ArcGIS Server allows you to publish your data (i.e. shapefiles, tables, feature classes) as a service so that is accessible through a URL.  The JavaScript API uses these URLs so that it can consume and map the data.
DanPatterson_Retired
Do you have a few references you have consulted so that people don't have to provide the obvious links to the help topics and the GeoNet Space on ArcGIS Server?  I suspect that you need more indepth information than is provided in those links.
SG
I have read the resources and help topics related to it but I really couldn't find as to what ArcGIS Server does. I am trying to use the JavaScript API but what does ArcGIS Server have to do with it.
JakeSkinner
Hi SG,
SG
thank you. How does one actually use those URL's and create Web Apps through the developers.esri website? I mean there is a sandbox for coding in JavaScript and also IDE's but how does one actually create a web map app to be viewed on a website?
RobertScheitlin__GISP
SG,
   This link will help explain what Jake is saying:
ArcGIS Server services overview | Guide | ArcGIS API for JavaScript
