ArcGIS Server StartUp Error
3144
02-09-2016 03:54 AM
EphraimMuya
I need help debugging an ArcGIS Server (10.3.1) StartUp error that i keep getting.
service_error.log:
java.lang.NullPointerException
    at com.esri.arcgis.discovery.admin.plugins.LogServiceObserver.a(LogServiceObserver.java:55)
    at com.esri.arcgis.discovery.admin.plugins.LogServiceObserver.beforeStart(LogServiceObserver.java:49)
    at com.esri.arcgis.discovery.nodeagent.impl.ObserverManager.beforeStart(ObserverManager.java:146)
    at com.esri.arcgis.discovery.nodeagent.impl.NodeAgent.c(NodeAgent.java:246)
    at com.esri.arcgis.discovery.nodeagent.impl.NodeAgent.start(NodeAgent.java:138)
    at com.esri.arcgis.discovery.nodeagent.impl.Main.start(Main.java:56)
MichaelRobb
Honored Contributor
You can see what exactly is going on by manually running c:\Program files\ArcGIS\Server\framework\etc\scripts\startserver.bat   ...
you will see exactly where the hangup is...
