When refreshing my web application, I was surprised not to only hit '304 Not Modified' responses when querying my ArcGIS Server services for the layer properties with the following URL:
https://gis.company.com/arcgis/rest/services/General/Data/MapServer/86?f=json&token=Foo
What I noticed is that if you query your ArcGIS Server VM individually:
https://gisVM01.company.com:6443/arcgis/rest/services/General/Data/MapServer/86?f=json&token=Foo
https://gisVM02.company.com:6443/arcgis/rest/services/General/Data/MapServer/86?f=json&token=Foo
and compare the responses, they are identical (to notepad at least) but they both have a different "Etag" header.
As a consequence, cache cannot be leverage.
It looks like ArcGIS Server machine is creating the Etag header by taking into account specific properties to the VM. As I am hitting my servers in a round robin way behind a load balancer, I always have 50% layers responses with 304 Not modified and 200.
Do you observe the same phenomena ?
Completely reasonable point. I’m not saying the geodatabase type by itself is the cause. I’ve just noticed in a few environments that services backed by a centralized SDE tended to look more consistent across nodes, while file-based data deployments sometimes showed more variation. Either way, agreed it’s worth validating with a couple targeted tests.
On your question about the full REST call: yes, the REST call I meant is the basic layer resource endpoint:
https://<cname>/arcgis/rest/services/General/Data/MapServer/86?f=json&token=<token>
For troubleshooting, it also helps to hit each node directly and compare headers:
https://<machine1>:6443/arcgis/rest/services/General/Data/MapServer/86?f=json&token=<token>
https://<machine2>:6443/arcgis/rest/services/General/Data/MapServer/86?f=json&token=<token>
Also, just to be clear: keeping the token stable during testing is simply to avoid changing the URL between requests (general HTTP caching behavior). I couldn’t find specific Esri documentation describing how ArcGIS Server generates ETags or whether the token is included as an input.
