ArcGIS server is not displaying user names, IP address or the machine name of the client systems while querying logs through “ArcGIS Server Manager”
1364
05-05-2019 11:46 PM
MADHUNOWPADA
It has been observed that ArcGIS server is not displaying user names, IP address or the machine name of the client systems while querying logs through “ArcGIS Server Manager” or login via REST/admin.
Is there any option / configuration changes needed / solution for accessing the user names, IP address or the machine name (who access the map services) for root cause analysis of severe errors in the “ArcGIS Server Manager” logs.
Many Thanks in advance.
DanPatterson_Retired
You have triplicate posts.  Please use the "Share" option instead
RickVillarreal
I am having this same issue. Very frustrating
