I saw that ArcGIS Server 11.1 Utility Network and Data Management Patch 4 is available. However, when I run the patch notification tool (as Admin), the "Install All Patches" button is grayed out.
This is the first time I'm seeing a patch available, but not able to install it. What might be the cause?
The MSP file also appears to not be downloading for me when I click the download link in the ESRI page:
Apparently the patch was pulled by ESRI due to technical difficulties
