ArcGIS Server Geoprocessing Results
646
10-21-2013 11:07 AM
DanPajak
I've created a geoprocessing service that selects a parcel by attributes, uses the selected parcel to search by location for all parcels within 300 ft. It then returns a table with an ownership list. I've made the selected parcels & owner list parameters in modelbuilder, then publish the service. I can see the list in a flex viewer but when trying to view the selected parcels it seems the geoprocessing service returns all of the parcels from the entire parcel layer, not just the selected ones. It works perfectly in ArcMap.
In the service editor, when publishing, under parameters I've selected view results with a map service.Using ArcGIS Server & Desktop 10.1 and Flex Viewer 3.4.
I'm obviously missing something.
MichaelVolz
Esteemed Contributor
Jeremy:
Were you ever able to resolve this problem?  I'm currently working on a similar task and I am having issues with the geoprocess processing time and the output location.
If you are willing to share your code I could try it out on my system.
