ArcGIS Server 10.9.1 Backup - Export operation failed. null
6848
14
01-20-2023 07:06 AM
mgress12
When attempting to backup an ArcGIS Server 10.9.1 site using the backup utility the following error is returned.
  • Export operation failed. null
The same error is returned when attempting to export the site through ArcGIS Server Administrator.
Setting logs to debug there is a java.lang.NullPointerException but I don't see anything else to help diagnose.
Does anyone have any suggestions to help troubleshoot?
ChristopherPawlyszyn
Can you include the stack trace that's included with the NullPointerException at debug-level? If the exception is thrown during the copy method one way to determine what file is corrupted would be to use a tool like Process Monitor (on Windows) and filter to the config-store and directories location to see what file is accessed last when that error occurs.
-- Chris Pawlyszyn
BillFox
MVP Notable Contributor
Hello mgress12,
do you see any more detail if you run the command directly in a dos window?
does it give an error about SSL?
does your ArcGIS Server have a CA-signed certificate? if not, try adding the --ignoressl switch to your backup command line.
mgress12
Thanks for the replay and suggestions!
No other details are provided through the command window.
I tried adding the --ignoressl parameter and get the same error.
BillFox
there's this old bug - listed as fixed with 10.8.1
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDExMzMzOQ==
BillFox
mgress12
Thanks, I stumbled on those articles as well but no luck so far with the listed workarounds.
BillFox
is portal in your picture that you can verify webgisdr tool too?
mgress12
This one is a stand-alone server.
Scott_Tansley
MVP Regular Contributor
What location are you trying to back up to?  Does the server service account have permissions to write to that location?
Scott Tansley
https://www.linkedin.com/in/scotttansley/
-- Chris Pawlyszyn
