ArcGIS Server 10.5 - Identify (MapServer)
2770
08-16-2021 04:46 AM
TasadduqHussain
In ArcGIS Enterprise 10.5,when i publish Map service through database (Oracle),identify not shown values on my map click.
Any solution will be highly appreciated
Thanks
DavidPike
MVP Notable Contributor
via what means are you consuming the service e.g. Pro, arcmap or Portal etc? If it's a Web Map it may be as simple as enabling popups https://doc.arcgis.com/en/arcgis-online/reference/configure-pop-ups.htm
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-pop-ups-mv.htm
TasadduqHussain
I am using ArcGIS Enterprise10.5 Map Service.
TasadduqHussain
Issue facing screenshot.
George_Thompson
Esri Notable Contributor
I just posted in your other post about this: https://community.esri.com/t5/publishing-and-managing-services-questions/popup-not-shown-results-thr...
Also may want to look at upgrading the Oracle geodatabase also to supported version, if it is 10.0 currently. I do not think that will fix the issue, but would not hurt.
--- George T.
