ArcGIS PostgreSQL 12.2 DBMS for Windows can't install pgAgent Extension
2204
5
10-07-2022 12:19 AM
Rémy_Gourrat
i'm very frustrated.
I use always the Esri setup "PostgreSQL 12.2 DBMS for Windows" download from myEsri space.
After setup, the pgAgent Extension is not proposed for creating.
How can repar it ?
thanks for your help
Rémy
George_Thompson
Esri Notable Contributor
Are you getting an error message?
What version ArcGIS are you planning on using?
Did you run the installer as an Administrator?
--- George T.
Rémy_Gourrat
thanks for your interest.
Connected in postrgres admin user, i  used this command
CREATE EXTENSION pgagent;
 and pgadmin return
SQL Error [58P01]: ERROR: can't open the file extension control « C:/Program Files/PostgreSQL/12/share/extension/pgagent.control » : No such file or directory
 it's true this file don't exist in this location.
I check in few arcgis enterprise in same version 10.8.1 postgresql 1.2 and it's same...
is there a good reason ?
can i download this extension somewhere ? it's a good idea ?
George_Thompson
I have not used or installed the pgagent on my postgres instance. I do not think it is needed by default.
--- George T.
Rémy_Gourrat
it's true, it's not needed by default.
by it's a very interesting pg standard extension to schedule some sgbd tasks like refresf materialized view or other things...
i'm worry that this extension is dropped in the esri setup....
George_Thompson
Honestly not sure. I have just used the installers from the PostgreSQL website for years with no issues. We just provide it to clients so they do not have to go search.
--- George T.
