ArcGIS Portal 11.5 crashes when requiring an ArcGIS Pro Licence
452
09-26-2025 07:49 AM
SimonReman2010
Hello everyone,
We recently upgraded ArcGIS Enterprise to version 11.5.
As expected, ArcGIS Pro licenses are now managed directly through the portal (no more License Manager).
However, we are facing a recurring issue: when an ArcGIS Pro 3.5 client tries to obtain a license from the portal, the portal sometimes crashes and restarts
The portal log shows:
The web server was found to be stopped. Re-starting it.
Has anyone experienced this issue or found a solution?
Best regards,
Simon
SimonReman2010
Update of 10/07/2025
When I enable the log level to debug, I get the following error during this incident.
java.lang.RuntimeException: java.util.concurrent.TimeoutException at com.esri.arcgis.portal.util.CallableUtil.execute(CallableUtil.java:31) at com.esri.arcgis.portal.util.TomcatUtil.startServer(TomcatUtil.java:109) at com.esri.arcgis.portal.plugins.ProcessMonitor.c(ProcessMonitor.java:281) at com.esri.arcgis.portal.plugins.ProcessMonitor$d.run(ProcessMonitor$d.java:538) Caused by: java.util.concurrent.TimeoutException at java.base/java.util.concurrent.FutureTask.get(Unknown Source) at com.esri.arcgis.portal.util.CallableUtil.execute(CallableUtil.java:29) ... 3 more
This error also appears in https://support.esri.com/en-us/knowledge-base/error-could-not-start-the-web-server-java-util-concurr...
I'm in touch with Esri Belux Support.
I'll provide another update when I get more information.
Best,
Simon
SimonReman2010
It seems that it is not related to ArcGIS Pro. We can reproduce the problem through the Portal Admin interface. From time to time the portaladmin/license/populateLicense crashes the portal.
We tried to regenerate a new licence file but it doesn't help
Best regards,
Simon
SimonReman2010
Here’s an update after two weeks.
Esri Belux support and consultants still have no idea about the origin of the problem.
I tried uninstalling and reinstalling the portal, but the issue persists.
I was also able to reproduce the problem in a completely different environment in the Azure Cloud.
Requesting the populateLicense operation several times causes the portal to reboot without any error message.
I’ll keep investigating.
Best regards,
Simon
Simon
