ArcGIS Image Service Display Issues
5576
10
08-29-2016 02:22 PM
MikeBly
HI All,
Publishing an image service to ArcGIS Server to be used as a map service in Geocortex. The image service is successfully published using a mosaic dataset. Have published from both FGDB and SDE  just to trouble shoot.
The issue is when I add the service to Geocortex I can just a checkerboard for the image. I am trying to determine if this is an issue with the steps taken in publishing the service on the ArcGIS side or if this is an issue within Geocortex. I am posting this in both forums.
During the publishing process I get no errors or warnings and get a smooth publication to Server. Images are referenced, mosiac dataset. In Geocortex they appear in the right geographic location  - just as a checkerboard and no image.
Thoughts?
THanks,
Mike
RandallWilliams
Agree with Jake. Sounds like your GIS Server has access to the Mosaic and service overviews but not to the source imagery.
https://community.esri.com/thread/68795
