ArcGIS Enterprise (Pro 3.0.1): How to disable the “move edits to base” option that’s set to a particular feature class?
871
08-31-2022 10:21 PM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, the versioning is set to be traditional with enabling “move edits to base” option. How the “move edits to base” option can be unchecked that’s already set for a particular feature class?
Jamal Numan
AyanPalit
I am thinking you are testing scenarios here. I suggest use the GP  Unregister As Versioned first.  Reference this documentation to review the Versioning Type that best meets your business requirements.
Thereafter, redo Register As Versioned  with appropriate options.
Ayan Palit | Principal Consultant Esri
AyanPalit
JamalNUMAN
Great. It works fine. By unchecking\rechecking the versioning option one can disable\enable the “move edits to base” option
Jamal Numan
