ArcGIS Enterprise Portal Upgrade Error 10.7.1
7884
20
09-04-2019 04:55 AM
SharfrajZaman1
I was trying to upgrade the ArcGIS Enterprise from 10.6.1 to 10.7.1. I was stuck with an issue and the error was " Failed to execute SQL file  C:\Program Files\ArcGIS\Portal\framework\template\sql\10.7.0_to_10.7.1\livingatlasdiff.sql "
Since in my case case it is a disconnected environment and I am not using internet in my machine and also I am not using livingatlas; so for the time being to troubleshoot the issue, I removed the "livingatlasdiff.sql" file from its original location (although kept it as a backup) and tried to upgrade the Portal which eventually upgraded successfully from 10.6.1 to 10.7.1. Does anyone faced similar problem and how it is resolved. Kindly let me know.
Portal Upgrade Error Portal upgraded from 10.6.1 to 10.7.1 successfully
jill_es
Thanks, Pål!  I just posted on the case itself and will be keeping an eye on it.
