ArcGIS Enterprise Portal 10.9.1 Login Faliure
1063
02-25-2022 02:27 AM
MuayadHussien
Hey there We’ve just got our arcgis enterprise 10.9.1 installed on a windows server 2019 working with a puplic ip linked to CloudFlare cdn and a firewall inside the network I set it up and configured the domain name and when i login to portal from outside the network it’s response as follow: (You don't have permission to access this resource.) and i can login from the arc gis apps like Collector and the other apps and i can even login to portal admin and server manager and server admin but when trying to login to portal  it’s redirected my request to this link https://mydomain/portal/sharing/oauth2/signin and here where is the error message come .
Tags (3)
Scott_Tansley
MVP Regular Contributor
have you set the webcontexturl in portaladmin?
Integrate your portal with a reverse proxy or load balancer—Portal for ArcGIS | Documentation for Ar...
Scott Tansley
https://www.linkedin.com/in/scotttansley/
MuayadHussien
Yes i did but may i ask if there is a proplem when the local domain match the puplic domain exactly like my Active Directory domain is the same as my global domain name and I noticed the portal link is extremely slow when opening it from out side the internal network (online)
Scott_Tansley
same domain shouldn't be a problem.  I have a setup where externally I'm something like:
 *.acme.com
and internally I'm:
  *.int.acme.com
But I use split DNS internally so my internal/external paths are all *.acme.com.
The reason for slowness is more likely to be infrastructure/latency issues than esri.  That can get a bit tricky to resolve on a forum, so you might want to look at ping tests, and speeds between components or for a more advanced approach use something like wireshark.
Scott Tansley
MuayadHussien
Thank you very much I’ll do that i can reach every thing except the portal link  when i enter the username and password and click login error 404 (You don't have permission to access this resource.) shown it’s look like an a authorization proplem the wired thing i can login from Survey 123 app and the others phone apps on my phone with the same account but only on the portal it’s happening!
Scott_Tansley
Have you used developer tools in your browser to look at the network traces?  My guess is that the answer is there.  What URLs come up with a 401,404
or other?
Scott Tansley
