ArcGIS Enterprise licensing
2917
07-22-2021 12:31 AM
Govindarajan
Hello All
Could someone help me in understanding the licensing level as in 10.8.1?
Question: Which of the following two combinations when published as a web map would require an editor license to add and remove features ?
Option 1:
Base maps from enterprise portal 10.8.1 or ArcGIS Online
Editable feature services from a federated/hosting published via portal?
Yes. We need a Editor license.
Option 2:
Editable feature services published from standalone ArcGIS Server?
My guess is no. Can someone confirm this?
1. Can editable WFS-T editable feature services published from an open-source GIS server can be added to the webmap?  Using the Add an Item from the web option in Portal mapviewer supports WFS but there is no reference to WFS-T?
Brian_Wilson
Honored Contributor
It looks like the way Esri prevents this is very simple, you can add a Geoserver WFS-T service to an Esri "map" but you cannot edit it.
In Geoserver, enabling editing means giving "complete" access to the service and setting appropriate permissions. (In my test, I enabled anonymous writes.) There is no separate support for WFS-T, just "WFS"
If you can't put a writable layer into an esri map, then you can't create apps either.
It looks like you can't edit WFS-T in ArcGIS Pro either.
You can use OpenLayers (I've never tried Leaflet) and QGIS to consume most Esri services but not the other way around.
I could see workflows where you could use open source to put data into a Geoserver WFS-T service and then view it in a webmap, for example automated collection via a GPS tracker.
Brian_Wilson
Honored Contributor
I am thinking the only hope of something working would be #3, WFS-T
What server are you planning on using for WFS-T? Geoserver?
Brian_Wilson
Honored Contributor
Govindarajan
Hi Brian
Yes, I am considering GeoServer for WFS-T. Just like to understand the impact on licensing
Govindarajan
Thanks Brian. You guessed it right. Just trying to propose a solution that would combine the best of both ArcGIS Enterprise and GeoServer WFS-T with an eye on licensing. However it appears that  this is not possible. Will keep exploring. Thanks for your support
