ArcGIS Enterprise 11.1 post-upgrade error - webhook requirements
5178
10
07-25-2023 08:37 PM
MatthewSchulze
We have recently upgraded our 10.9.1 ArcGIS Enterprise to 11.1 using ArcGIS Enterprise Cloud Builder for Microsoft Azure.
The process completed with one recurring error in the portal logs we have yet to address regarding webhook requirements on our ArcGIS Notebook server (see below)
Does anyone have any ideas on how to we can address this particular error?
Portal for ArcGIS error message:
WARNING - An error occurred trying to refresh the webhook configuration on server '<server URL>'. Please check server meets all webhook requirements [Portal Log code 218077]
Additional detail:
The error is repeating every 15 minutes in the portal logs but is only specific to the federated Notebook server (all other federated servers generate a 'success' log). This is consistent across two separate multi-tier ArcGIS Enterprise deployments we have recently upgraded to 11.1.
The error doesn't seem to be impacting users as we can still create ArcGIS Notebooks, configure a Webhook which runs a Notebook and the webhook responds when the configured criteria is met.
System details:
Windows Server 2019ArcGIS Base Deployment
Windows Server 2019ArcGIS Notebook Server
Additional ArcGIS Notebook Server Details:
Docker Desktop: v4.15.0
Docker Engine: v20.10.21
Docker Images: ArcGIS Standard + Advanced (10.9.1 + 11.1)
Related
Documentation read for troubleshooting:
Webhooks in ArcGIS Enterprise—Portal for ArcGIS | Documentation for ArcGIS Enterprise
Create webhooks—Portal for ArcGIS | Documentation for ArcGIS Enterprise
KevinHibma
If you navigate to:
https://sever/webadaptor/admin/system/properties
Click Update
Enter the following JSON (or append it)
{"isWebhooksEnabled":false}
You'll need to restart GIS Server.
This will prevent it from trying, thus no logs.
ReeseFacendini
Esri Alum
This is a known issue that's being worked on. Portal is requesting information for a webhook endpoint that Notebook Server doesn't support, during the federation checks. I'm not currently aware of a workaround for this, but it's safe to ignore those errors for the time being.
KevinHibma
Matthew,
Do you have ArcGIS Monitor installed? I'd like to understand why you're seeing the message on a 15minute interval. I wouldn't have expected to see this logged more often than every 30minutes.
For reference, this is the tracking issue number:  BUG-000159271
AL_77
@KevinHibma or @ReeseFacendini , we recently upgraded both of our Enterprise portals, 1. from 10.9.1 to 11.0 and 2. from 11.1 to 11.2.
After the upgrades we installed all patches. But we see this on both. The 11.0 ArcGIS server (Hosting) is seeing this error every minute while the 11.2 ArcGIS server log is showing it hourly. Any suggestions?
KevinHibma
The most common reason you see these errors are due to a closed port between the ArcGIS Server(s) and ArcGIS Data Store machine. Can you verify 45671 and 45672 are open?
AL_77
I have checked with our SA, and they said that they "I don't see anything blocking them. I also don't see any traffic to those servers over ports 45671 and 45672". I have also entered in a case with ESRI
KevinHibma
Something else comes to mind now that I read your upgrade path a bit closer.
Just so I understand, you had 11.1 (no observed errors), then upgraded to 11.2 (now seeing errors).
Are you using feature or geoprocessing webhooks? If not, I can give you the switch to disable them and it'll stop trying to recover webhooks, thus you won't see any errors. Otherwise, I think it's an issue logged recently (give this to your tech support analyst: BUG-000164209).
AL_77
No, we are not using any webhooks.
KevinHibma
If you navigate to:
Click Update
GiaNguyen2
Kevin,
I tried to follow this process by setting the webhook for false, I am still seeing this warning message. I am using portal 11.1. Any other suggestion
Bao
