ArcGIS Enterprise 11.0: How to enable\disable data store when publishing?
6987
20
10-02-2022 09:25 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to enable\disable data store when publishing
Jamal Numan
ChristopherCounsell
MVP Frequent Contributor
Hover over the button, does it give more information why?
Can you create a Hosted Feature Layer through the Portal for ArcGIS Interface? Sign into portal, go to Content, then Create Layer.
If you have not completed the ArcGIS Enterprise configuration (adding Hosting Server to Portal for ArcGIS) then I would expect this button to be greyed out.
JamalNUMAN
I couldn’t find the “create layer” button as per the screenshot below
Jamal Numan
ChristopherCounsell
Click "New Item" and then "Feature Layer"
You can also check the Portal organization settings under servers, to see the hosting server configuration.
JamalNUMAN
As per the screenshots below, there is no “feature layer” option while clicking the “configure server role” option ends up with “Unable to load the ArcGIS Server backing stores and/or the ArcGIS Server license information” error
Jamal Numan
JamalNUMAN
As per the screenshots below:
  • The grayed out “publish” button says that the “your portal doesn’t support publishing”.
  • The “jama” member is with “creator” user type
What might be the issue here?
Jamal Numan
ChristopherCounsell
@JamalNUMAN this was a quick test to see if you could create hosted feature layers.
From your response it appears that you have not completed the ArcGIS Enterprise deployment or there is something wrong with your hosting server.
You should have a federated ArcGIS Server with an ArcGIS Data Store, relational + tile cache data store, and then set this server as your Hosting server in Portal for ArcGIS. This is considered a minimum for a 'base deployment' of ArcGIS Enterprise. It is necessary for hosted feature layers and apps that would create them (e.g. survey123)
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-hosting-server-for-porta...
JamalNUMAN
  • The Relational ArcGIS Data Store and Tile Cache ArcGIS Data Store are configured
  • The federated ArcGIS Server is configured
But what do I need to do in order to “set this server as your Hosting server in Portal for ArcGIS”?
How this can be performed?
Jamal Numan
JamalNUMAN
As per the screenshots below, the “configure server role” option ends up with “Unable to load the ArcGIS Server backing stores and/or the ArcGIS Server license information” error
Jamal Numan
ChristopherCounsell
If you have ArcGIS Data Store licenced and configured with ArcGIS Server correctly, it may be communication issues between your Portal and Server. Even if they're on the same machine, you should consider them to be servers trying to communicate with each other. I've noticed you've configured the server as 'localhost'. I also see certificate warnings on your address bar. If you search that error code this is a technical article that comes up:
https://support.esri.com/en/technical-article/000025762
Personally I'd look to revisit how ArcGIS Enterprise was deployed, and try to have the machine names and certificates and trust between enterprise components all configured properly. Doing things like importing certificates into server, portal and data store will save you from a ton of unexpected behaviour.
If you have the opportunity to do so I'd strongly recommend checking out the Esri Instructor lead 'configuring a base deployment of ArcGIS Enterprise' course.
