ArcGIS Enterprise 10.9.1: Enabling Oracle 19.3 database fails and ends up with “Geodatabase must be created under SDE schema” error,
1253
09-22-2022 12:15 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why enabling Oracle 19.3 database fails and ends up with “Geodatabase must be created under SDE schema” error
“Geodatabase must be created under SDE schema.  You cannot create a geodatabase in Oracle in any other schema starting with ArcGIS 10.7 and ArcGIS Pro 2.3”
How this issue can be resolved?
Jamal Numan
George_Thompson
Esri Notable Contributor
When you run the enable you must have the SDE user / tablespace already created. Based on your screenshots, you need to run the Create Enterprise Geodatabase tool, since you have the "sys" user.
Here are the workflows; https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-oracle/setup-geodatabase-orac... for both paths.
--- George T.
JamalNUMAN
Performing the “create enterprise geodatabase” tool dnds up with the “ORA-12154: TNS: could not resolve the connect identifier specifiedNo extended error” error
What could be the issue here?
Jamal Numan
George_Thompson
just use the EZConnect string: ServerName/SID or make sure your TNS is configured correctly.
--- George T.
JamalNUMAN
The screenshots below show the content of the listener.ora and tnsnames.ora files. The “net manager” is also configured where the oracle home director is set to be:
C:\Oracle\Software\OracleDatabaseHome_X64_19.3
Nevertheless, the “create enterprise geodatabase” tool fails
What other issues I need to check?
Jamal Numan
