ArcGIS Enterprise 10.7.1 - How to delete Map Image Portal item from ArcGIS Pro 2.8.3?
1460
11-08-2021 08:04 AM
VincentLaunstorfer
It looks silly but I cannot delete Map Image items from ArcGIS Pro catalog... Deleting Feature layer items work ok but deleting Map Image layer is not possible.
I receive a message asking to use ArcGIS Server Manager
Is there a reason for this? Ir does not facilitate portal items administration...
(deleting directly on Portal do work for info)
Thanks
ABishop
Hello @VincentLaunstorfer
I did a google search based on your question and I found this information:
https://enterprise.arcgis.com/en/server/10.7/publish-services/windows/deleting-a-service.htm
Looks like best practice is to delete the services from the server manager site.
Amanda Bishop, GISP
VincentLaunstorfer
Thanks for that. Unfortunately, I am not the ArcGIS Server administrator and cannot rely on ArcGIS Server Manager.
I wonder why it is not possible to delete Image layer items in ArcGIS Pro catalog when I own these items, while directly logged in Portal, I can delete these items. There must be a reason.
ABishop
Can you request that the ArcGIS Server Administrator delete the services for you?  Or give you admin rights to do so?
I haven't had much luck deleting services from catalog.
Amanda Bishop, GISP
