Hi there,
We are having the same issue as described here
When validating the data stores via the admin API I see the same token error coming from data store
Validate: Machine 'https://...:6443/arcgis/admin/generateToken' returned an error. 'Failed to log in. Invalid username or password specified.'
then the
failed to log in. Invalid username 'some guid' or password specified.
The only place I've seen any sort of credentials stored is in the dsadmindb in the <data store schema> storeregistry table. There are the following columns auth,storekey, storepwd, sharedkey and regtarget that store some encrypted data - are these related back to Server and are we able to reset this auth if it is the auth that the data store uses to try to generate the token. In the other post @JonathanQuinn says
"Data Store shouldn't store the PSA credentials as Server supports those credentials changing. It should establish a trust between itself and the Server."
How is this trust established and can we reset it without having to unregister the data store - which seems to be the common fix in the thread.
Fraser
I hadn't considered portal as I got stuck focusing on the generate token from the GIS server in the logs. But if the error goes away when it can talk to portal then it must be in the mix. Good thinking Scott!
Thanks also to @FraserHand for digging into the depths of data store and also suggesting re-registering in his original post!
We are having the same issue with an 11.3 Portal. We did try and run the unregisterdatastor and received an error. "Unable to perform this operation because the GIS Server site registered with this data store is not available". Uuuuugh!
We had the same issue after changing the password of the primary site admin (version 11.3). We resoved it by running the "registerdatastore.bat" on the data store machine. It seems to change the "owningsys"-parameter in the dsconfig$ from couchdb. Everything is working fine since then.
