Features won't draw after filtering by date
555
08-06-2024 01:57 PM
BenClark
When filtering referenced data by date field in a web map, Experience, or Web Appbuilder application, none of the features will draw although their tabular records will display correctly. I should also note that I've recently upgraded to 11.3 from 10.9.1 and it used to work as expected under the old version. Filtering the same data by its various text fields works fine. Anyone else run into this?
Thank you,
Ben
