Arcade Expression with HTML, TextFormating.NewLine doesn't work ?
3391
7
12-05-2023 02:23 AM
JasonBOCQUET
Hello, I have an attribute expression like this :
var transactions = FeatureSetByRelationshipName($feature,"SDE.TRANSACTIONS")
//return transactions
// Build the pop-up string by iterating through all related features
var info = ''
for (var f in transactions){
    info += "ID : " + DefaultValue(f.TRA_ADR_ID, 'no data') + TextFormatting.NewLine +
        "Nom immeuble : " +
        DefaultValue(f.TRA_NOM_IMMEUBLE, 'no data') + TextFormatting.NewLine +
        "Montant : " +
        DefaultValue(f.TRA_MONTANT, 'no data') + TextFormatting.NewLine +
        "Acquéreur : " +
        DefaultValue(f.TRA_ACQUEREUR, 'no data') + TextFormatting.NewLine + TextFormatting.NewLine
iif(isempty(info),'Pas de transactions','Transactions utilisateurs :'+TextFormatting.NewLine +TextFormatting.NewLine+info)
and it returns me that :
It's good for me but i want to improve my pop-up windows with some HTML.
So I try this code (it's only a short part of the code) :
var info = ''
       "Nom immeuble : " +
        "Montant : " +
        "Acquéreur : " +
HTML += "<p style='text-align: left;'><span style='font-size: 16px; font-family: Calibri, sans-serif;'>"+"<strong>"+iif(isempty(info),'Pas de transactions',TextFormatting.NewLine +TextFormatting.NewLine+info)+"</strong></span></p>"
But it returns me this :
It seems that the TextFormatting.NewLine constants do not work in the arcade window but only in the attribute expressions window? Or did I make a mistake in my code?
ZachBodenner
MVP Regular Contributor
One of the utilities of the backticks is so that you don't actually need to rely on textformatting etc.
https://developers.arcgis.com/arcade/guide/template-literals/#:~:text=Template%20literals%20can%20co....
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/manage-your-strings-quite-literally-...
Here are some ESRI provided resources that can provide a little more info.
And here's one more example of using the backticks to make writing HTML returns a bit easier
//set variables. First variable is the unique ID that is shared by the primary and related data. Second variable is calling the related forms as a FeatureSet
var treeGlobal = $feature.GlobalID;
var relatedForms = FeatureSetByName($map, "Tree Inventory Form")
//create a filter statement where the maintenance form GUID = the Tree Inventory GlobalID
var filterStatement = "TreeInv_Rel = @treeGlobal"
//a maintenance form equals the table run through the filter
var inspForm = Filter(relatedForms, filterStatement)
console (inspForm)
if (isEmpty(inspForm)) {
  var title = ``
else if (!isEmpty(inspForm)) {
  var title = `<div style="text-align:center"><b>Inspection Records</b></div><br>`
// Sort related features by oldest to newest
var relatedDataSorted = OrderBy(inspForm, 'Date ASC')
// Build the pop-up string by iterating through all related features. Add or subtract new lines in the popupString as needed from the related form.
var popupString = ''
for (var f in relatedDataSorted){
    popupString +=
        `<div style="text-align:center"><b>${Text(f.Date, 'MMMM DD, Y')}</b></div><br>
        <b>Maintenance Performed: </b>${DefaultValue(f.Maintenance_Performed, 'No maintenance performed')}<br>
        <b>Maintenance Performed by: </b>${DefaultValue(f.Performed_By, 'No maintenance performed')}<br>
        <b>Condition:  </b>${DefaultValue(f.Condition, 'Condition not assessed')} <br>
        <b>Chemical Used (if any): </b>${DefaultValue(f.Chemical_Treatment, 'No chemical treatment')} <br>
        <b>Amount Used (if any): </b>${DefaultValue(f.Chemical_Qty_ML, 'No chemical treatment')} <br>
        <b>Notes: </b>${DefaultValue(f.Notes, 'No notes')}<br><br>
return {
	type : 'text',
	text : `${title}
  ${popupString}`
You'll notice the backticks enclose my final popupstring variable and I just include an extra <br> tag at the end of the loop. That way, multiple related record come in with some breathing room between each.
Happy mapping,
- Zach
ZachBodenner
If you're going to be returning HTML in the Arcade popup element, you need to use template literals (so enclose your variable HTML in  backticks (`) instead of quotes ("), and then use the HTML tag <br> instead of textformatting.newline. Then, remove all the plus signs and enclose your variables in brackets preceeded by a $.
var info = ''
       "Nom immeuble : " +
        "Montant : " +
        "Acquéreur : " +
HTML += `<p style="text-align: left;"><span style="font-size: 16px; font-family: Calibri, sans-serif;"><strong>${iif(isempty(info),'Pas de transactions'},<br> <br>${info})</strong></span></p>`
Give that a try and see if it works, though there might still be issues with the HTML return portion ${iif(isempty(info),'Pas de transactions'},<br> <br>${info}). You may want to assign that to it's own variable, and then just use that new one in the final HTML return so it would look like:
var newVariable = iif(isempty(info),'Pas de transactions',info);
HTML += `<p style="text-align: left;"><span style="font-size: 16px; font-family: Calibri, sans-serif;"><strong>${newVariable}</strong></span></p>`
Happy mapping,
- Zach
jcarlson
Just a note: HTML generated by Arcade will only work using the Arcade popup element.
https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/part-1-introducing-arcade-pop-up-con...
You might check out using the Arcade element to return a field list, too. Takes care of some of the styling and formatting for youl
- Josh Carlson
Kendall County GIS
JasonBOCQUET
Thanks for your replies both of you.
I don't understand one thing, i can use the HTML with Arcade like i write here :
var immeuble = $feature.lp_nom_immeuble
var id_lp = $feature.id_lp
var adresse = $feature.lp_num_voie + ', ' + $feature.lp_nom_voie + ' ' + $feature.lp_code_postal + ' ' + $feature.lp_ville
var surface = $feature.lp_surface_totale
var construction = $feature.periode_de_construction
var etat = $feature.etat_general
var nature = $feature.destination_principale
var loyer = $feature.loyer_moyen
var vacance = $feature.taux_de_vacance
var offre = $feature.offre_en_cours
var HTML = "<p style='text-align: center; line-height: 0.1;'><strong><span style='font-size: 30px; font-family: Calibri, sans-serif; color: rgb(1, 42, 132);'>"+iif(IsEmpty(immeuble),'',immeuble)+"</span></strong></p>"
HTML += "<p style='text-align: center; line-height: 0.1;'><span style='font-family: Calibri, sans-serif;'><em><span style='font-size: 12px; color: rgb(1, 42, 132);'>"+iif(isempty(id_lp),"Pas d'ID Logipro","ID Logipro : "+id_lp)+"</span></em></span></p>"
HTML += "<p style='text-align: left;'><span style='font-family: Calibri, sans-serif;'><strong><span style='font-size: 16px; color: rgb(1, 42, 132);'>"+adresse+"</span></strong></span></p>"
HTML += "<p style='text-align: left;'><span style='font-size: 16px; font-family: Calibri, sans-serif; color: rgb(1, 42, 132);'>"+iif(surface < 1,"Pas de surface renseignée","Surface de "+"<strong>"+surface+" m²")+"</strong></span></p>"
HTML += "<p style='text-align: left;'><span style='font-size: 16px; font-family: Calibri, sans-serif; color: rgb(1, 42, 132);'>"+iif(construction < 1,"Pas d'année de construction renseignée","Année de construction : "+"<strong>"+construction)+"</strong></span></p>"
HTML += "<p style='text-align: left;'><span style='font-size: 16px; font-family: Calibri, sans-serif; color: rgb(1, 42, 132);'>"+iif(isempty(etat),"Pas d'état renseigné","État de l'immeuble : "+"<strong>"+etat)+"</strong></span></p>"
HTML += "<p style='text-align: left;'><span style='font-size: 16px; font-family: Calibri, sans-serif; color: rgb(1, 42, 132);'>"+iif(isempty(nature),"Pas de nature d'immeuble renseigné","Nature de l'immeuble : "+"<strong>"+nature)+"</strong></span></p>"
HTML += "<p style='text-align: left;'><span style='font-size: 16px; font-family: Calibri, sans-serif; color: rgb(1, 42, 132);'>"+iif(loyer < 1,"Pas de loyer moyen renseigné","Loyer moyen de "+"<strong>"+loyer+" €/m²/an")+"</strong></span></p>"
HTML += "<p style='text-align: left;'><span style='font-size: 16px; font-family: Calibri, sans-serif; color: rgb(1, 42, 132);'>"+iif(isempty(vacance),"Pas de taux de vacance renseigné","Taux de vacance de "+"<strong>"+(Round(vacance, 4)*100)+"%")+"</strong></span></p>"
HTML += "<p style='text-align: left;'><span style='font-size: 16px; font-family: Calibri, sans-serif; color: rgb(1, 42, 132);'>"+"Offre en cours : "+"<strong>"+offre+"</strong></span></p>"
HTML += "<p style='text-align: center;'><span style='font-family: Calibri, sans-serif; font-size: 20px; color: rgb(1, 42, 132);'><strong>Transactions utilisateurs</strong></span></p>"
to build a pop-up like this :
And it works, all of the code that I write works.
So why I have to use backticks and <br> for that if everything else works ?
Can I only use this replacement to make a line break or it's mandatory to change all of my code ?
@ZachBodenner I try your code but it doesn't change anything, I don't understand what I have to make in <br> tags ?
ZachBodenner
First, I tried this (plugging your Arcade into my own data)
var PID = $feature.PID
var HTML = ``
//var newVariable = IIF(isempty(PID),"Pas d'ID Logipro","ID Logipro : "+PID)
//HTML += "<p style='text-align: center; line-height: 0.1;'><span style='font-family: Calibri, sans-serif;'><em><span style='font-size: 12px; color: rgb(1, 42, 132);'>"+iif(isempty(PID),"Pas d'ID Logipro","ID Logipro : "+PID+TextFormatting.NewLine+$feature.Address)+"</span></em></span></p>"
//HTML += `<p style='text-align: center; line-height: 0.1;'><span style='font-family: Calibri, sans-serif;'><em><span style='font-size: 12px; color: rgb(1, 42, 132);'>"${newVariable}<br>${$feature.ADDRESS}"</span></em></span></p>`
HTML += "<p style='text-align: center; line-height: 0.1;'><span style='font-family: Calibri, sans-serif;'><em><span style='font-size: 12px; color: rgb(1, 42, 132);'>"+IIF(isempty(PID),"Pas d'ID Logipro","ID Logipro : "+PID)+"</span></em></span></p>"
return HTML
The expression validates but doesn't actually return anything in my Arcade popup element. So then I tried to plug the variable HTML into the arcade return that exists when you add a new Arcade popup element:
var HTML = ``
//return HTML
return {
	type : 'text',
	text : HTML
That got me somewhere:
Then I tried adding the new newline formatting that you included in your original post:
var HTML = ``
//HTML += "<p style='text-align: center; line-height: 0.1;'><span style='font-family: Calibri, sans-serif;'><em><span style='font-size: 12px; color: rgb(1, 42, 132);'>"+IIF(isempty(PID),"Pas d'ID Logipro","ID Logipro : "+PID)+"</span></em></span></p>"
//return HTML
return {
	type : 'text',
	text : HTML
But I did wind up with the same issue as you:
Then I tried using the template literal formatting, with backticks, and using the <br> tag to create the carriage return (you don't need to close the break tag, just put it somewhere where you want a new line, along with placing the IIF in a separate variable:
var HTML = ``
//return HTML
return {
	type : 'text',
	text : HTML
And that got me where I think you want it to be?
I think if you're using the Arcade element, it makes the most sense to utilize that
return{
    type: 'text',
    text:
statement, which allows you to utilize the backticks notation and shorten the code a bit. As to why...I'm sure someone else could answer that question better than me.
Hope that helps!
Happy mapping,
- Zach
JasonBOCQUET
I use actually the return things.
The point is this : I have a function to get all of my transaction associated at one building (relationship class between building shape and transaction table).
there is the code :
var info = ''
       "Nom immeuble : " +
        "Montant : " +
        "Acquéreur : " +
On one building i can have N transactions associated, so when I click on my pop-up of the building shape, i can see all of the transaction associated, and all of the variables on the transaction are separated by a "TextFormatting.NewLine" to make a line break between variable so the information it show like that :
and between each transaction, i would make a line break to have a more airy text.
But i think the HTML have to be integrate directly in the function who recover my transaction information (so the part of the code that i share to you in this post) no ? But it is possible to do that ?
On your previous exemple, you can't parameter the HTML on the contents of the expression that you write, it's only on the expression himself when it called.
Because I try your thing, and all of my transaction are packed like this :
here is the code :
var info = ''
       "Nom immeuble : " +
        "Montant : " +
        "Acquéreur : " +
HTML += `<p style="text-align: left;"><span style="font-size: 16px; font-family: Calibri, sans-serif;"><em><strong>${newVariable}<br></strong></span></p>`
return {
	type : 'text',
	text : HTML
Maybe i miss something in your explanation but i didn't get the point of the utility of the backticks notation to resolve my problem ?
ZachBodenner
console (inspForm)
  var title = ``
    popupString +=
return {
	type : 'text',
	text : `${title}
  ${popupString}`
Happy mapping,
- Zach
JasonBOCQUET
Ok i understand !
In practice i suceed to combine my typping method with " and your technic with backtricks and it works for what i want to produce. Thanks you !
