Arcade expression for pop-up attachment
3096
6
03-28-2024 07:29 AM
Rémi
Hi, I found in this post https://community.esri.com/t5/arcgis-online-blog/show-attachments-in-pop-ups-with-arcade/ba-p/890588 how to display the first attachment. I'd like to view the other attachments by retrieving the list of attachment identifiers using arcade to calculate a new field:
//calculate the attach IDs field
function IDs(f){
return f.ID;
var Attach_ = Attachments($feature);
var AttachIDs = Map(Attach_, IDs);
return Concatenate(AttachIDs,',');
I don't understand why this isn't working. Can you help me?
2 Solutions
jcarlson
You can do it with a simple loop, no need to use Map (though it would make for more concise code).
var atts = Attachments($feature)
var ids = []
// loop through attachments and get the ids
for (var a in atts) {
  Push(ids, atts[a]['ID'])
return Concatenate(ids, ', ')
- Josh Carlson
Kendall County GIS
Rémi
Thanks a lot for your help
jcarlson
Hard to say why it isn't working. Try adding a couple Console statements to see what each step is doing, as that can identify where the process is breaking down.
function IDs(f) {
  return f.ID;
Console(Text(Attach_));
Console(Text(AttachIDs))
- Josh Carlson
Kendall County GIS
Rémi
Thank you for your reply. I get the following error : invalid expression. Error on line 8 Unknown function
jcarlson
Are you running this expression in ArcGIS Enterprise? Map was introduced at 11.0, so if you're on an earlier version, you won't have access to it.
- Josh Carlson
Kendall County GIS
Rémi
Unfortunately, I'm in version 10.9!
I don't know how i can retrieve attachment identifiers...
jcarlson
var ids = []
- Josh Carlson
Kendall County GIS
Rémi
