Arc Server 10.1
3513
10
01-22-2018 03:26 AM
FelipeAlves
How to fix this problem: "Service's containing process has crashed."
XanderBakker
Esri Esteemed Contributor
Here is a support document where you can start. Error: Services containing process crashed. ServiceName.GPServer instance has crashed  and there is this solved thread: https://community.esri.com/thread/66569
FelipeAlves
Thanks! I checked PythonPath but the registry is pointing to the correct path C: \ Python27 \ ArcGISx6410.1 \ Lib; C: \ Python27 \ ArcGISx6410.1 \ DLLs; C: \ Python27 \ ArcGISx6410.1 \ Lib \ lib-tk.
XanderBakker
I would have suggested to contact Esri support, but as of this year version 10.1 has been retired: https://support.esri.com/en/Products/Enterprise/arcgis-server/ArcGIS-Server/10-1#product-support  and there is no support for this version. Do you have the possibility to upgrade to a more recent version?
You will have to provide a lot more details about the hardware server is installed on, how the service is configured (including scripts), etc in order for someone here to help.
JayantaPoddar
What is the OS?
Could you try repairing the ArcGIS Server installation?
Think Location
FelipeAlves
Hello. Windows Server 2008 R2.
I am afraid of the impact repairing can have on the application
George_Thompson
Esri Notable Contributor
Did you happen to have any Windows patches applied to your server machine lately?
Problem starting PublishingTools Service
https://community.esri.com/message/744099-re-instance-of-the-service-systempublishingtoolsgpserver-c...
--- George T.
FelipeAlves
Automatic update occurred, I already uninstalled
George_Thompson
And this issue is still present? If so, you may need to upgrade to a new version of ArcGIS Server, as xander_bakker‌ mentioned earlier.
--- George T.
FelipeAlves
At the moment I have no conditions to buy a new arc server
