Adding licenses for additional cores
5036
07-21-2021 09:55 AM
MaryGraceMcClellan
I am upgrading our two ArcGIS Server machines (in a High Availability configuration) to each have 16 vCPUs, which is an increase from their current 8 vCPUs each. My org's Esri rep has confirmed that our ELA will cover the additional licenses that will be needed, but I'm not sure if I have to manually add the license or if it will happen automatically.
More details: ArcGIS Enterprise 10.7.1 Base Deployment, Servers are configured as hosting server for Enterprise
Has anyone dealt recently with adding licenses to accommodate increased cores?
JayantaPoddar
No need to authorize the license again. The same ArcGIS Enterprise (already authorized in the same machine) will work on higher core as well.
You could refer Licensing ArcGIS Enterprise Deployments in Virtualized and Cloud Environments
Think Location
JayantaPoddar
Think Location
MaryGraceMcClellan
Thanks! That should make things easier.
ReeseFacendini
Esri Alum
Like @JayantaPoddar  said, there's no additional steps you need to take.  The license needs to be valid in MyEsri for the 16 cores, as far as our terms and conditions is concerned.
