A method to check how our services are healthy
13252
43
07-08-2017 11:33 PM
rawansaleh1
I couldn’t figure out if there is a method to check how our services are healthy.
For example, I need a tool to send a notification for me if one of my services are stopped suddenly or any failure happened to my services.
I need any method to make a periodic check on my services.
Any suggestion for that?
Best,
Rawan
Tags (1)
AlaaFlaifel
Thanks in advance.
by Anonymous User
Not applicable
Hi All
Please check with this to find status of map services health
# -*- coding: utf-8 -*-
import requests
r = requests.get('http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer')
print r.status_code
print'ESRI_Census_USA'
r = requests.get('http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer')
print r.status_code
print'TaxParcel/AssessorsBasemap'
r = requests.get('http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/TaxParcel/AssessorsBasemap/MapServer1')
print r.status_code
print'TaxParcel/AssessorsBasemap1'
Result
==================== RESTART: D:/Avinash Test/probing.py ====================
200
ESRI_Census_USA
200
404
let me know for any issue
JonathanQuinn
Esri Notable Contributor
This won't necessarily test the health of the services, only if they're up or not. Data issues could cause the service to return a 200 when checking to see if the service itself is accessible, but making any type of request for data, (query or exportMap), will fail. I'd suggest you just run a simple query to see if it returns data and also use built-in modules, (even though requests is far easier to work with), (where 1=1 and returnCountOnly = True). If you do want to query all services, keep in mind that it will submit a bit of load on the Server and, if the data is coming from a geodatabase, the geodatabase as well.
AlaaFlaifel
Thanks!
I'll try this.
Best,
Alaa
