The Create List does not work since our upgrade to 10.9.1. I contacted ESRI and support went thru our logs and index, he indicated everything was good.
I go to item details, data, fields, then try to create list. I get an error.
Is there a step I am forgetting? Thank you for you help, Annette
Solved! Go to Solution.
What worked for me is adding something into Description, after that I was able to create a list.
This workaround is now added tot the BUG by Esri: https://my.esri.com/#/support/bugs/BUG-000144906
Thanks @Anonymous User that workaround solution did the trick for me. I was frustatingly confused after our upgrade
Thanks for your post @Anonymous User. I was wracking my brain trying to figure out why our new toy wasn't working
