Hi Rick,
I suspect the issue you are running into is because Python is trying to use SSLv3 by default to communicate over HTTPS and this is disabled on Portal 10.3.1. What specific version of Python 2.7 are you using? I believe Python 2.7.8 is the last version to try to use SSLv3 by default but unfortunately that is the version distributed with Server and Desktop 10.3.1.
Here are a couple of ways to address it:
1. Override the default protocol used by Python. There are multiple ways to do this but the simplest I've found is to add the following to the beginning of your script:
import ssl
ssl.PROTOCOL_SSLv23 = ssl.PROTOCOL_TLSv1
2. Download and use a later version of Python 2.7 to run the portalpy scripts. If I'm correct about the version, anything after 2.7.8 should work. One caveat with this approach though. These newer versions of Python also enable SSL certificate verification by default. This causes problems connecting to Portal over :7443 because a self-signed certificate is used which cannot be verified. If you choose to upgrade to a newer version of Python and want to disable the SSL verification, I'd recommend adding a snippet of code outlined here.
Jeff
